I have an ISO I ripped from a japanese music video I own. And I'm trying to shrink it to fit on a 4.7gb DVD-R and when I open the Disc in DVDshrink it won't let me adjust the compression low enough to fit on a backup disc...
Anyone know what I can do to make this fit? I've tried switching to custom ratio and it wont let me go lower than what it is set to in automatic.![]()
You have two choices
1. Use DVD Rebuilder and re-encode instead. this is probably the better options.
or
2. Run it through Shrink and save the results to your HDD. Load the Shrunk version into Shrink and shrink it again.
Personally, I think if you have to Shrink it twice then you are asking for low quality and should use DVD Rebuilder instead, or seriously consider using a DL disc.Read my blog here.
Fazeshot, your problem seems to be the inclusion of a PCM soundtrack. There is no simple way of compressing this. I strongly suggest you rip the video and audio elements separately, convert the PCM track to AC-3 (or MP2), then re-author as a new DVD. Complex I know but better than crucifying the video quality in order to fit in the PCM track.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
DVD Fab - DVD Shrink - DVD Decrypter OK, and disc is unusable?
By dledm in forum DVD RippingReplies: 7Last Post: 1st Jun 2010, 15:54 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59
