Hello!
I have a video project filmed and rendered in 16:9 using Sony Vegas. I then used ConvertXtoDVD, using automatic (it lookes as if the aspect ration is maintained when processing) aspect ratio setting. Finally, I used Nero to burn the files to DVD.
But... the DVD still shows up as 4:3 on my widescreen TV. Changing the setting (on the tv) to Wide does makes the project look ok sizewise - but the color tone substantially weakens and it looks somewhat washed out.
My questions are:
1. How can I make the tv automatically understand that it's 16:9, which it does on regular DVDs as well as projects I've made (on other computers) with DVD Studio Pro?
2. Why do the colors look washed out when the tv is set to widescreen, even though the aspect ratio looks fine (it's the other way around in 4:3 or zoom mode - bad ratio but good colors)
I would be extremely grateful for a quick reply!
/ Dan A (Stockholm, Sweden)
Why are you using ConvertXtoDVD ?
Output as DVD compliant 16:9 mpeg from Vegas, author with GUIForDVDAuthor and burn with Imgburn. ConvertXtoDVD and Nero have no place in this scenario.Read my blog here.
I used those programs as I thought rendering to AVI would produce the best video quality.
I guess I could try rendering again, this time in mpeg, if you think it will be equal in quality?
Thanks for your help!
Aspect ratio problem: Converting 2.35:1 AVI to DVD w/out squishing
By Calidore in forum Authoring (DVD)Replies: 31Last Post: 1st Apr 2015, 12:33 -
Nero 10 Recode - Aspect Ratio problem?
By The.King in forum Video ConversionReplies: 6Last Post: 18th May 2010, 14:34 -
AVI to DVD aspect ratio always wrong
By Focaldesign in forum ffmpegX general discussionReplies: 22Last Post: 26th Jan 2009, 19:18 -
AVI to DVD with different aspect ratio
By germ in forum ffmpegX general discussionReplies: 16Last Post: 7th Apr 2008, 23:50 -
AVI to DVD..... vary aspect ratio
By GJF in forum Video ConversionReplies: 5Last Post: 10th Jul 2007, 06:03
