First of all, this is the hardware I own and that is part of the problem I am having:
Motorola MoxiBox BMC9012
LiteOn 1107HC1
I am currently trying to use my DVD recorder, a LiteOn 1107HC1, to record a TV show that I previously recorded with my MoxiBox BMC9012. So I basically just want to record the show while the MoxiBox is playing it in real-time. Unfortunately, the DVD recorder won't even start recording but displays a message saying "Protected Content" instead. I suppose this is due to the DRM that is implemented in the MoxiBox. Is there any way to work around this? If necessary, buying new hardware is also an option. It must work with the TimeWarner cable subscription, though, since that is something I cannot change. Are there DVD recorders that won't detect DRM? Or, even better, are there other set-top boxes that I can use with my TimeWarner subscription that do not have DRM or allow me to burn DVDs using an internal DVD recorder? I just had a look at the Polaroid DRA-01601A but am not sure whether it fulfills all my requirements.
Thanks a lot in advance!
Some content on cable is protected and some can't even be recorded. I don't suspect you have this issue with all content recorded on the Moxi. If you do, then I would suspect a Moxi issue. There isn't a way to remove the DRM. Some of the Moxi boxes have built in DVD recorders, but even those won't burn DRM protected material. DRM is most commonly used by the movie channels (HBO, Showtime) and by the Pay Per View channels. I've also read where some DRM encoded programs will auto delete after a specified time frame.
Google is your Friend
Panasonic DMR-EZ485V recording problems
By ray best in forum DVD & Blu-ray RecordersReplies: 64Last Post: 18th Aug 2015, 18:19 -
AVerTV Hybrid Volar HX digital recording problems
By TO MOYTRO in forum Capturing and VCRReplies: 7Last Post: 15th Jan 2011, 07:36 -
Dish DVR Help: Recording problems
By IxCAINExI in forum Newbie / General discussionsReplies: 5Last Post: 1st Nov 2008, 10:19 -
Problems with recording analog video from my Nintendo 64 console...
By Nintendo Fan in forum Capturing and VCRReplies: 2Last Post: 25th Oct 2008, 18:25 -
Line in Microphone recording problems
By sara82 in forum AudioReplies: 3Last Post: 10th Jun 2008, 16:53
