    Aug 2007
    Hi
    I want to make a DVD with Menus and submenus. Basically what i want is a main menu with two options:
    Play Movie
    Submenu to Trailers
    In the submenu I'd then have the 4 trailers associated with the movie.
    I've tried Nero Vision Express which is really easy to use but it doesn't support submenus (at least as far as I can see). I've also tried Sonic which creates the submenu no problem but when I add the avi movie it puts the size of the project up to 6gig and therefore to big to burn to disc.
    Is there software out there that allows me to do what i want in an easy and simple way? Or is there a way of doing what i want using Nero or Sonic?
    Many thanks in advance for any help
  2. I use DVD Author Pro for all my authoring. It's great and will do what you're wanting.
    Feb 2004
    Australia
    Dosent get much simpler than dvdauthorgui , and there's plenty of guides covering menu's .
  4. to quote "but when I add the avi movie it puts the size of the project up to 6gig" Authoring software alone isn't what the OP wants as I see it.
    the OP wants a 1 click wonder!?
    Maybe TDA 3 which can encode and author with menus and submenus would work.
    Try the trial version. https://www.videohelp.com/tools/TMPGEnc_DVD_Author
    It should do what is wanted as far as I see.
    Cheers
