  1. Member g_pentium's Avatar
    Jul 2007
    Malaysia
    i was supposed to burn a audio cd with 20 songs in it,using Nero Express 7,before i could burn,i was welcomed with this message!
    This compilation contains too much data to fit on the disc with respect to the normal disc capacity.Do you want to try overburn writing at your own risk?(This might cause read errors at the end of the disc or might even damage your recorder.)
    Required capacity: 715MB
    Total capacity on disc: 701MB
    Note: SCSI/ATAPI errors may also occur at the end of the stimulation or burning.Even then,the CD/DVD may still be readable but the written data needs to be verified.
    Click 'OK' if you want to overburn writing on the disc.
    instead of 20 songs,i burned my audio cd with 19 song,due to space constrains.If i carried on with overburn will this spoil my burner?
    Hi
    Oct 2005
    666th portal
    715mb is definitely out of the range of any normal burner and might destroy it. 703-4 maybe. you might try getting rid of the 2 second pauses between tracks and editing the songs to get rid of any dead air time to reduce their size.
    May 2001
    Wow! None of the above is true. Most newer drives today can easily burn 750+ Megs - just do a Google of 90 minute, 95 minute and 100 minute CD-Rs. Nero has a list of your drives capability - it wouldn't have suggested that course of action if it could not be accomplished.
    Destroy it? I suppose that with the integrated SELF-DESTRUCT-WHEN-715MB-IS-DESIRED routine, your drive could have erupted into an enormous fireball, but product safety rules today have mandated that these routines be removed from the firmware.
    In short, you are fairly safe in overburning with your drive.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  4. Member g_pentium's Avatar
    Jul 2007
    Malaysia
    thats a relieve!
    so anymore disadvantages and advantages in overburning that i need to know~?
    Hi
  5. Banned
    Jun 2007
    UNREACHABLE
    http://cdrecord.berlios.de/old/private/man/cdrecord-2.0.html teaches:
    -overburn
    Allow cdrecord to write more than the official size
    of a medium. This feature is usually called over-
    burning and depends on the fact that most blank
    media may hold more space than the official size.
    As the official size of the lead-out area on the
    disk is 90 seconds (6750 sectors) and a disk usu-
    ally works if there are at least 150 sectors of
    lead out, all media may be overburned by at least
    88 seconds (6600 sectors). Most CD recorders only
    do overburning in SAO or RAW mode. Known exceptions
    are TEAC CD-R50S, TEAC CD-R55S and the Panasonic
    CW-7502. Some drives do now allow to overburn as
    much as you might like and limit the size of a CD
    to e.g. 76 minutes. This problem may be circum-
    vented by writing the CD in RAW mode because this
    way the drive has no chance to find the size before
    starting to burn. There is no guarantee that your
    drive supports overburning at all. Make a test to
    check if your drive implements the feature.
    May 2001
    Nero has a tool called CDSPEED that can do an overburning test of your particular brand of CD. It should give you some idea on just how much you can overburn. I have some really cheap 80's that I can get 2:35 minutes extra on them. I also have some 90 minute CDRs that my Yamaha burner handles okay. However, with the extra length burns, you run into the problem of some players not being able to read the leadin properly. My CD player in my car has this problem. But then, 90+ is in the "extreme overburn" area.
    Dec 2006
    Here,where do you think?
    SLK001 wrote" Most newer drives today can easily burn 750+ Megs."
    I agree,just burned 767mb cd on a 700 mb 80 min disc ,using burrrn on 20 wav files...
    " Who needs Google, my wife knows everything"
