Ok this is a simple question. You know how a VCD is 80min with 700mb right? and a standard vcd is like 1250 kbit/s right? so that would allow you to fit 80 min on 700mb, can u fit a movie thats 90 min on a 700mb cd if i lowered the bitrate? then the size would be smaller right? and it should techinaclly fit right?
yes that works. problem is that most standalone dvd players won't recognize any vcd longer than 82 minutes
I've made a 91min VCD, plays fine on my Apex AD600A (but then the Apex lines plays pretty much any/every thing). If you lower bitrate quality will go down. However, depending on your source and how you encode the quality hit varies.
If it's a DVD rip, 3-4pass VBR might still look pretty good. If it's a DivX source... well
I know that flipping discs is annoying but bulk CDRs are ~$0.25/ea so I try to put ~60min per 80min CDR.
It would work but I think you would loose more picture quality then you want.
If the movie has any credits in it or a long intro I would try cutting them out to shorten the movie. -
I have made a dozen or so vcd's from 85-95 minutes using the new 99 min cdr's, they all play fine on all my players, these include a pioneer dv-c503, fisher 1100, apex 660ad, and daewoo dvd/tv combo.
Simple Question re Premiere CS5
By jkholmes in forum Newbie / General discussionsReplies: 10Last Post: 3rd Mar 2011, 22:50 -
A simple trimmer for real media files
By kutchbhi in forum Newbie / General discussionsReplies: 7Last Post: 22nd Sep 2009, 08:29 -
HD DVD .EVO to .MKV (I need a real simple method)
By craig198 in forum Blu-ray RippingReplies: 0Last Post: 26th Aug 2008, 14:24 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 02:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 22:10
