Hi,
I created a home video that is in avi (dv) format. I tried to use several encoders to convert the avi file to a DVD compatible file to burn to a disk. DVD Flick was the easiest and fastest encoder I used but there are a few places in the video where it looks like there are interlacing artifacts (horizontal lines blurring the video). I don't get this with the other encoders but they are much slower. I tried using 1 pass and two pass, and also tried using the deinterlacing. (The deinterlacing version had the worst results.) Is there some option in DVD Flick that I may be missing that may help? Thanks in advance for your help.
Hardly seems worth the effort to get DVD Flick to work if in fact other apps you have are successful.I don't get this with the other encoders but they are much slower.
You'll notice that most folks have a number of different apps/encoders that they use. One size does not fit all. -
1. which other encoders?
2. is dvd flick faster than ConvertXtoDVD?Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-) -
Hi,
I used My DVD V5 (Sonic). Its old but it worked. My wife liked the results so its a done deal. The encoding was slower but I get a full, authored and ready to burn, DVD. (I don't have ConvertXtoDVD so I can't comment on the product.)
I'll try your suggestion Baldrick (FAVC with HCEnc) when I get a chance. But, now that the video is finished I have to finish the livingroom floor and fix the heating system. So it might be a little while. BTW, thanks for the whole website. I'd be nowhere with this stuff without Videohelp.com -
Dude, its obvious that the other apps r quite slow.Originally Posted by MysticE
I'd recommend convertx2dvd if you can find it.
Av2 dvd is also quite slow.
for me: CX2d made a DVD in 80 minutes, four TV episodes and Avi2DVD did it in 4-5 hours.
do the math ....Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-) -
When I read "home video that is in avi (dv) format' I guess I wrongly assumed QUALITY would somehow enter into the picture. For your downloaded TV shows any of the popular one click apps will suffice. All the free encoders tend to be slow, but they also do a great job. I ain't in no hurry, I can really appreciate the results that HCenc provides and their authors who constantly hone them. My hat also goes out to those who create the free front ends that tie all these various freeware apps together making for free solutions that produce results of the highest quality. Easy to find and freely distributed. And no "if you can find it" caveat needed.Originally Posted by ********
what is the fastest avi to mpeg2/ac3 demuxer in your opinion?
mpeg2 = m2v or mpv or whatever
ac3 = mp2
Or lemme put it like this:
what is the fastest way to convert an avi into files that DVDauthor will accept?
apologies if i mix things up.Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
DVD Flick
By majordad in forum Authoring (DVD)Replies: 18Last Post: 6th Nov 2011, 14:17 -
dvd flick
By bloodymoon6 in forum Video ConversionReplies: 2Last Post: 4th Feb 2010, 18:43 -
DVD Flick & ISO size issue
By jnojr in forum Authoring (DVD)Replies: 8Last Post: 6th Jan 2010, 18:57 -
DVD FLICK
By sm173 in forum Video ConversionReplies: 2Last Post: 29th Mar 2009, 14:32 -
DVD flick region issue
By 123fish123 in forum Newbie / General discussionsReplies: 7Last Post: 16th Jun 2008, 22:25
