hi i know that you can use a background mpeg in TDA but this means if you make it from a jpeg, the quality is very low. I notice you can select a jpeg and get a nice good quality background but Im not sure how to add audio to this?
Has anyone had any experience of this?
There's no reason why an MPEG made from a JPEG should be any lower image quality. The limiting factor is the video resolution you're using such as 720x576 for PAL and 720x480 for NTSC.Originally Posted by tikigod19
it is definately noticeable.. it is a nice high res image but when i put into adobe premiere and add music, export as a high quality avi then convert to 720x576 mpeg it is instantly lower resolution.
I'm not sure what I am doing wrong in the conversion aspect, but I think I will look for alternative authoring software. Has anyone got any good suggestions? -
Use TMPGEnc Plus 2.5 or similar to encode a still frame with audio track at 720x576 then import into TDA as a background image.
i just tried that but im getting 'invalid video source'. At first I thought it was because jpeg wasnt on the drop down menu so I converted to bmp which is one of the files it looks for, but still get the error..?
This is after choosing DVD - PAL (720x576) from the initial menu
audio encoding: tmgenc dvd author 3 vs. tmpgenc plus
By cL0N31 in forum Newbie / General discussionsReplies: 0Last Post: 7th Jan 2009, 00:25 -
DVD Menu Image Buttons With Video Background
By sk8_aholic in forum Authoring (DVD)Replies: 3Last Post: 20th Nov 2008, 00:01 -
Normalize Audio with TMPGEnc DVD Author 3?
By jonas more in forum AudioReplies: 2Last Post: 16th Oct 2008, 22:10 -
Tmpgenc DVD Author 3 Custom Background Quality?
By haym in forum Authoring (DVD)Replies: 1Last Post: 29th Jul 2008, 19:49 -
Background clip from movie - TMPGEnc DVD Author 3
By gayclarke in forum Authoring (DVD)Replies: 3Last Post: 11th Sep 2007, 03:02
