I know this question has been asked a couple of times,but I still can't seem to find the answer.
I have a problem thats been buggin me 4 the last couple of days. I have a video thats a wmv, but because I'm starting think they are kinda unstable with my players I really want to convert it to xvid avi.I've tried abot 6 different converters, but every outputted video it OUT OF SYNC with the audio.
Iv'e read on some forums that newer wmv's tend to have variable framerates, which can (and has) proved to be a pain in the ass.
Does Anyone have any suggestions or advice as to how I can convert these vids with the audio problems.
So far I've I tried simplemencoder,winavi, super,TMPGenc,TMmpgenc express and a couple others..
Thanks in advance
Results 1 to 11 of 11
Have you tried Windows Movie Maker? Export to DV-AVI with it and then convert to Xvid with any converter like AutoGK.
I think the program Any Video Converter will do the trick in just one step. Just select audio as "original" when converting.
somethings interfering with it. unfortunately, you usually have to remove one program at a time to determine this (or add them one at a time if reformatting your hdd). codec packs are highly suspect.
I just might have to do that as my last option.
Does anyone know how I can use avisyth to open up the wmv's ? using the converfps method? -
DirectShowSource() works for me.Originally Posted by TonyRomo1227
http://avisynth.org/mediawiki/DirectShowSource
Jim -
did you successfully convert a variable frame rate wmv using that method?
I posted my reply before you edited.Originally Posted by TonyRomo1227
I do use "convertfps" in my wmv AviSynth scripts, and encode to DVD using TMPGEnc Plus.
I don't have my scripts in front of me (they're on the home computer), but IIRC I use the basic:
DirectShowSource("my_video.wmv", fps=29.97, convertfps=true) - not 100% sure on the "fps" setting, but I think that's right.
Been doing this about once a week for a year or so, on the "Cranky Geeks" vidcast, so that I can watch from the comfort of my sofa
Hope that helps,
Jim
AVCHD Lite Help: WMV and/or XviD conversion
By tarrickb in forum Video ConversionReplies: 43Last Post: 31st Jul 2009, 20:55 -
Audio synch issues when converting to XviD or DivX
By baduncan in forum Video ConversionReplies: 3Last Post: 15th Dec 2007, 13:25 -
wmv to avi (divx/xvid) conversion jumpy output file
By famine99 in forum Video ConversionReplies: 5Last Post: 14th Oct 2007, 11:09 -
By famine99 in forum Video ConversionReplies: 0Last Post: 11th Oct 2007, 21:04 -
Joining Xvid files with MP3 audio (VBR) without loosing synch?
By fk in forum EditingReplies: 6Last Post: 31st Jul 2007, 19:19
