If I am backing up a DVD that is larger than 4.7G, I understand that CloneDVD compresses the video. Does it do the same to the audio or is that copied 100%?
Transcoders (CloneDVD, DVD Shrink etc) only work on video. They look at the original encoding and remove data. It is the reason they are so fast, but also why the quality falls away fairly quickly in many cases as well. Audio makes up such a relatively small % of the total volume that there is little to be gain by reducing it's size, but you will lose quality.
Read my blog here.
Need help with Audio stream format, VD/M won't compress
By talefing in forum Newbie / General discussionsReplies: 7Last Post: 15th Mar 2010, 13:22 -
VirtualDub: "The audio codec cannot compress the source to the desired
By user2008 in forum Capturing and VCRReplies: 6Last Post: 12th Jun 2009, 20:35 -
Simplest and fastest way to compress LPCM audio to fit on DVD5
By kurbads in forum User guidesReplies: 5Last Post: 18th Sep 2008, 04:15 -
wmv encoding, cannot compress audio
By kidcash in forum Newbie / General discussionsReplies: 7Last Post: 27th Jan 2008, 15:58 -
can't compress audio in vdub
By Shaorin in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 06:26
