Hi all,
I followed the ffmpegx guide for converting to XviD using MPEG4[.AVI] (mencoder) and found that when I add the "Use B-frames" option I get flashes of pixelation in my video. I understand that B-frames can cause compatibility issues in some hardware players, but can this apply to playback with Quicktime and DivX Player as well?
Flashes of pixelation may happen if the bitrate is too low and/or the quantizer parameter is too high. QuickTime 7 with the DivX® Component or the DivX Player should have no problem with B-frames per se on a normal 10.4 system.
By the way, MPEG4 [.AVI] (mencoder) is not XviD, but libavc mpeg-4 codec. Very similar, but not the same.
Are you using ffmpegX 0.0.9x r2 (current version)? Just checking, as you didn't mention a version number.
I am using 0.0.9x r2. I found that if I use XviD[.AVI](mencoder) with the same settings there is no problem using B-frames. I didn't think there was that big a difference as they both use mencoder.
Thanks for your help.
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 18:31 -
Pixelation in certain frames while playing files in a DVD player
By aarelovich in forum Video ConversionReplies: 8Last Post: 4th Feb 2010, 14:47 -
Vobsub causing pixelation on upper RH corner?
By Uzysuicide in forum SubtitleReplies: 2Last Post: 7th Feb 2008, 17:13 -
Watching videos on my computer results in weird pixelation and blurring
By dan1230 in forum Newbie / General discussionsReplies: 9Last Post: 4th May 2007, 11:46
