Hello!
I just edited, encoded, and authored a short video as I've done many times before. When I went to Imgburn to build & then write, I was surprised to find Imgburn took forever to load and even longer to respond to menu inputs etc. I was able to build & write, but not without problems. Also it took forever to kill it if I wanted out. It just sucked up all the system resources and dragged the whole computer down. Did a complete uninstall/reinstall to no avail. All other applications run just fine. Where do I start looking ????
Thanks!
oh the movie never ends...
Thats not a fault with imgburn .
When was the last time you ran system scandisk , and completely defraged the hard drives .
Video editing is a system intensive process , and moving big files about all the time dosent help .
You may even want to run manufacturer's diagnostic tools on the hard drive to confirm all is well with performance .
Shut system down , and remove ide cable from drive and motherboard , then plug back in , firmly , yet carefully ... dont go bending pins .
Sometimes a cable can be a little off with transfers ... they don't last forever .
Check bios and hardware device manager to confirm drives set mode ... primary / secondary ide ata / atapi controllers .
Advanced settings tab .
Locate and download hijackthis , do system scan , save log , and report back ... you may have other issue causing problem ... Only download imgburn from genuine websites ... their are parasites out their just waiting . -
as a P.S. to BJs list, check in Device Manager that your drive is still set for DMA or Ultra DMA --- I've seen reports that system crashes and such-like can cause a drive setting to slip back into (sloooowwww) PIO mode.
grannyGeek ~~
Antique Newbie
Where to start? I'm a amateur photographer and I want to start out in video
By James Wright in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jul 2015, 15:12 -
Nero vs ImgBurn: Why is ImgBurn preferred?
By usually_quiet in forum Authoring (DVD)Replies: 31Last Post: 28th Aug 2010, 18:47 -
M2TS conversion and playback slower than Molasses in January
By HighVoltageMiner in forum Video ConversionReplies: 2Last Post: 13th Jan 2010, 16:45 -
Philips DVP5990/F7 turned out ot be...
By toshik in forum DVD & Blu-ray PlayersReplies: 17Last Post: 4th Mar 2009, 23:36 -
Upgraded to ImgBurn 2.2 - Now "ImgBurn Shell Ext" No Longer Works
By Cool Breeze in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th May 2007, 11:05
