hi, how hard is it to setup and configure apache web server? I know apache is a free download but is there anything else i need to download with it? I tried it in the past but didn't keep it for long. Is it geared towards beginers like me? or is it for more advance high level. What if i don't have a domain name and all that? Can i setup that for free?
Results 1 to 10 of 10
Apache is fairly easy to set up. Just go to www.apache.org and read up before you try to install.
Depending on how your internet connection is set up, it is fairly easy to create a no domain web host.
If you have a router, set it up so it forwards http requests (port 80) to your server (the computer with apache). You can sign up for an account at www.no-ip.com
There's even guides on how to use it here
Basically, a program runs on the server that tells no-ip to re-route requests for your web domain (for example php111.no-ip.org) to your computer. The program always runs and tells the no-ip site what your current IP is, such as in the case of a dynamic IP. -
Will you help me setup and configure in a messenger? There are fatal errors installing it.Originally Posted by Supreme2k
Which part has fatal errors? Apache? No-ip?
What is the OS of the server?
Did you read the install instructions thoroughly?
And especially, check here:
http://httpd.apache.org/docs/2.2/faq/ -
For testing purposes you could install either xampp or Easyphp . Believe each is one click install and you have test server up and running. Both include php, mysql etc.
Something like the Apache foundation has been denied but the message came up so fast just out of the eye. I really would like to start using apache. Would someone like to help me and trouble shoot? I am using vista i hate it and no i have not read the documentations.
What Vista are you using? When I first got a machine that had Vista Ultimate installed, it had User account control turned on, which blocked most every program I use. After turning it off, I was better able to network and serve files.
Your best bet is to have a dedicated server that is not used for day-to-day applications. My server is an "old" 1ghz XP machine that runs apache, php, mysql, etc. I also have the same config set up for Linux (Ubuntu) on another drive.
I did my install hands-on, as I like to work with the "guts" of a system. You may have better luck, as coalman suggested, with Easyphp, though it looks like xampp may be a bit easier.
I try to be as helpful as possible, but I'm not one for hand-holding. I'm a little impatient and would rather just fix a problem myself, rather than try to blindly instruct someone else. -
oh i am using Vista Home. I rather use Apache. How do i turn off User account control? How can i setup and configure apache and forward to port 80 or port 8080? I am one of them guys that needs help configuring and setting up. I rather not use anything else but apache.Originally Posted by Supreme2k
Again, thoroughly read the manuals on the Apache site, if you don't want to use one of those One-Clicks olutions.
I tried xampp, and it works excellently. No hassles.
And especially if you are looking for help, you need to provide as much info as you possibly can. Start by answering all of the questions I've asked. List your system information as well as how you connect to the internet. -
The programs I listed both run apache , might be worth it to install them and poke around a little to familiarize yourself. They come pre-configured. One thing to be aware is you do not want to use them live. They are not meant for that. Running a server properly is by no means something that can be explained fully in a forum there's too many and's, if's and but's. As suggested thoroughly read the documentation.Originally Posted by php111
Recording Stream on local computer : Streaming Server Wowza Media Server 2
By iLove in forum Video Streaming DownloadingReplies: 2Last Post: 19th Apr 2012, 16:25 -
New server
By Baldrick in forum FeedbackReplies: 7Last Post: 26th Jan 2012, 06:55 -
install Win2008 Server STD Government Volume License on Server with no O/S
By retroborg in forum ComputerReplies: 5Last Post: 11th Nov 2008, 09:18 -
GURU feedback needed: web server encoding and .flv size
By lucite in forum Video ConversionReplies: 4Last Post: 15th Feb 2008, 18:28 -
Web Server / Call Pilot info
By Lucifers_Ghost in forum ComputerReplies: 1Last Post: 5th Jul 2007, 11:37
