    Sep 2003
    HI,
    I have been using Avi2DVD to convert avi files to dvd on my computer and have been having GREAT results. I install it on a other faster computer and now when I load the same avi file that work great on my 1st computer, this one comes up with this ERROR "Floating point division by zero" and I click OK and the program freezes or locks up. Is there something I need to load to make this program work?
    justmenow55
    Oct 2006
    Portugal
    Install the last release of the program, and the problem will be solved
    Sep 2003
    Thank you, Half-Life
    I found the lastest update and it solve my problem.
    This is a great forum!
    justmenow55
