I've ripped the DVD using MactheRipper to a single vob file.
I want to convert it to use on my iPod. I've tried Ipod and Ipod TV, to convert...and the video comes out fine, but the audio sounds like chipmunks. I've looked around and over the last several days I've tried passthrough audio....converted to 44100 Hz....and all sorts of other things.... Nothing seems to work. Any clues/suggestions here?
Oh I've also tried conversion to PSP...which worked for a .flv file...but again...chipmunks. I've tried ac3 audio for the conversion as well.....
I'm currently trying audio with .ac3(dolby digital) as the output....
I have the same problem and it is really annoying. The only thing that I've been able to do as a work-around is to quite the damn app, restart and try again with the same settings. This is an extremely quirky app with a tremendous amount of unpredictability and/or complexity of choices.
If you figure out a solution, please post it as a reply.
There are several things to try. Since you've already ripped it as a single vob, you're all set to demux it into its separate streams. Once you've gotten that far, you can try using ffmpegx to perform a direct audio-to-audio transcode; you might have better luck. If not, you can use another audio conversion tool, such as Audacity, which tends to be pretty robust.
If you've soured on ffmpegx altogether, and wish to convert into divx/xvid, D-Vision3 is hands-down the best tool for the job. First, it's free. Second, it has a well-polished user interface that makes choosing correct settings very straightforward. It converts audio into 128kb/s MP3 by default, but you can change the bitrate up or down (and choose Ogg instead, as well).
Trouble using Handbrake 0.9.5 to convert DVD to iPod
By courtnet85 in forum DVD RippingReplies: 11Last Post: 14th May 2011, 01:08 -
Convert movies from my ipod touch to PS3 and DVD Player
By d_unbeliever in forum Video ConversionReplies: 5Last Post: 13th Jun 2009, 07:05 -
Cannot convert 1 title to ipod from self-authored DVD...
By BeachNut in forum DVD RippingReplies: 2Last Post: 4th Feb 2008, 12:48 -
What is the best freeware tool to convert a DVD to iPod?
By xoADAMox in forum Newbie / General discussionsReplies: 6Last Post: 8th Jun 2007, 22:18
