Can someone tell me a video player or a filter that will work with Zoomplayer, Windows media player, Bs player, or VLC player that will allow me to raise the audio pitch of a video file on playback. (No re-encoding and no delay in playback, thanks)
Closed Thread
I know this isn't the magic bullet you were asking for, but it'll work...
In Adobe Audition, extract the audio from the video. You can then manipulate the audio any way you choose, including raising the pitch of the audio without changing the length. Once you've got your audio the way you want it, save it and remux.
What's your final product going to be? Are you doing this for burning to DVD or do you just want to watch on PC?
one topic is enough, https://forum.videohelp.com/topic334591.html
$$$ for help removing high pitch "ssss" sound
By paudieshea in forum AudioReplies: 22Last Post: 8th Jan 2015, 17:35 -
Flash with high quality video (MP4 with H264 video and AAC audio)
By Baldrick in forum User guidesReplies: 49Last Post: 19th Mar 2010, 10:05 -
How do I completely remove audio over a certain pitch?
By z-kun in forum AudioReplies: 3Last Post: 10th Mar 2010, 10:19 -
AutoGK Preview (High Pitch Voices)
By Blue_3 in forum AudioReplies: 0Last Post: 28th Mar 2008, 21:27 -
Audio Pitch Problem
By Bully9 in forum AudioReplies: 6Last Post: 18th Jan 2008, 02:41
