if i tick the little box with dl next to it,
the one under the auto fit, what will it do.
whats it used for the dl box?
dl - dual layer.....
sorry for been thick
but what does it actually mean
do i need to tick the box? -
This page:
https://www.videohelp.com/dvd
It depends on what you're doing whether it needs ticked. If you don't know what it means, you most likely need to leave it alone.Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
echo cancellation, auto volume, auto gain
By pror0ck in forum AudioReplies: 1Last Post: 10th Sep 2011, 07:01 -
PowerDirector auto-transition? auto-audio fade?
By yic17 in forum EditingReplies: 1Last Post: 16th Mar 2011, 15:59 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 09:59 -
auto fit
By roystheboy in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Jun 2008, 06:23 -
Auto-fit seemingly creating larger DVD's
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 16th Oct 2007, 17:08
