I saw a similar topic, but it dealt with AVI files, so I'm asking in a new topic for clarity. I have MPG files, converted from DVR-MS files, where the audio is consistently 1-2 seconds later than the video. It doesn't appear to be a gradual thing, as far as I can tell - the audio remains off by the same interval throughout the file. Is there any way to fix this?
As an aside, seeing the mentions of AVI everywhere, is AVI a better format than MPG? I considered AVI, but I think the converter I tried at first had bad AVI support, so I just went to MPG for simplicity.
https://forum.videohelp.com/topic334086.html
avi is a container.
there are many formats you can put in an avi.
what are your plans for the video file?
optimally you'd demux mpeg2 and the audio from the dvr-ms
what did you 'convert' with? how long did it take?
used to be a program called dvrtompg. m$ probably locked down on it.
you could probably find it, ,if you looked hard enough
anyway i have no contact with dvr-ms
gl -
how do you convert to mpg? are the dvr-ms files out of sync?
As suggested see if the original files are insynch. If they are then you should reconvert them.
I would recommend using directshowdump it works with the type of files you are working on. You need the .net framework installed for it to work - it is free from microsoft.
I use it to strip my tivo fles off my tivo into ready to use mpg files. The transfer is pretty quick.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
At this point, I'm just watching recorded TV files on my computer. I may wish to burn to DVD later, however.Originally Posted by 45tripp
what did you 'convert' with? how long did it take?DVRMStoMPEGGUI; however, I realized that that's not the issue after finding a few source files I thought I'd deleted. The problem is that when I delete commercials manually using Avidemux, that gap is added. Since it's not a gradual delay, but a steady delay from beginning to end, I'm pretty sure it can't be an incorrect FPS.Originally Posted by Baldrick
Panasonic digicam to mpg puts audio out of sync
By ronhud in forum Newbie / General discussionsReplies: 5Last Post: 5th Apr 2012, 10:25 -
Importing .mp4 into Vegas puts unwanted pixels in video
By HaffaWaffle in forum EditingReplies: 8Last Post: 8th Oct 2011, 00:40 -
Audio/Video Sync Issue with .mts File Conversion
By arturo_morosoff in forum Video ConversionReplies: 2Last Post: 4th May 2010, 10:52 -
i captured a video from reciever in .mpg format, [ a conversion problem] !!
By aSem-1 in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 17:22 -
mpg video conversion out of sync
By pettinej in forum Video ConversionReplies: 2Last Post: 14th Oct 2008, 21:49
