hi, Is it possible and how can i burn a AVI Divx on to a DVD? I tried burning it twice with Nero. It worked but it wouldn't play on the DVD Player for some reason. I burned it as a DVD ISO. The first time i dragged the folders over. The second time i dragged the movie without the folders.
				Results 1 to 13 of 13
	Is your DVD player Divx certified? Regular DVD players don't play Divx AVI files.
	I don't know if it's certified. I sent you a PM.Originally Posted by jagabo
	Divx certified players usually have a Divx certified logo printed on them. Or look through the manual to see if it mentions Divx or MPEG4. Or search through the DVD Players database here for the model number and see if it plays Divx/Xvid/MPEG4.
 If the player doesn't play Divx files you'll have to convert to standard movie DVD format. There are many guides here regarding AVI to DVD conversion. ConvertXtoDVD is a popular program for that.
	jagabo, Do you know if VirtualDub or VirtualDubMod can handle loading DVD mpg's to join them? I know VDub and VdubMod is mostly for AVI's.
	sorry but i don't want to join the VOB. I wanted to join the MPEG's. You know when you convert from one format to DVD before you author? In my case, I have a split mpg.Originally Posted by jagabo
	TMPGEnc Plus has MPEG joining and cutting tools. Many DVD Authoring applications will let you join as you author.
	jagabo, I have a question for you. First i am trying to re-encode my movie once again i keep messing with no audio. All the other times in TMPGEnc DVD author i get a message saying something like illegal audio stream. I tried to repair the ac3. I used ffmpeggui to convert from mp3 to ac3 then in the authoring there are two files one was an mp3 i have demuxed and the other is the one i created with ffmpeggui so in DVD author i load the file that ffmpeg made as ac3 illegal audio stream. Could you give me some details so i don't have to re-encode again?Originally Posted by jagabo
	What authoring program do you use and what audio converting tool do you use that is complete freeware not payware?Originally Posted by jagabo
  Converting WMV to burn on DVD to play on DivXBy ez2cy in forum Video ConversionReplies: 30Last Post: 20th Dec 2008, 04:54
  DivX File, How Do I burn To DVD???By jam90 in forum Video ConversionReplies: 3Last Post: 27th Jan 2008, 15:49
  What's best to burn to DVD: XVID, DIVX, AVI?By peterj in forum Authoring (DVD)Replies: 3Last Post: 17th Jan 2008, 08:35
  What's the right way to burn Divx onto a DVD+R?By mk2006 in forum Authoring (DVD)Replies: 11Last Post: 14th Jan 2008, 15:37
  How do I burn Divx file on to a CD.By Leak in forum Newbie / General discussionsReplies: 3Last Post: 7th Jul 2007, 13:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
