Hi, what is the easiest way to resize a movie from 720x476 to 720x480. I am trying make menues by using Ulead DVD Movie Factory. But since the size is 720x476, program is not recognizing as a valid MPEG file. Should I use TMPGEnc or some other program? Can someone walk me through. Thanks in advance
You have to re-encode the MPEG to change it's resolution. It might be possible to load the MPEG in AVISynth and use the add borders (or resize), then load in Virtual Dub and save as an AVI. But I don't know if Ulead will use an avi source to make menus?
Otherwise re-encode in TMPGenc (or your fav encoder). Question 720x476 is a very odd resolution, it's not divisable by 8 so I'm not even sure it'll play on your TV... -
I can play it on Pioneer DV333. I burned on RW CD and played. It worked fine without any problem. Everything is fine. But I want to add menus and the only program I have is Ulead DVD Movie Factory and it does not recognize it as a valid file. Thanks
How to resize and convert MPEG-2 file so I can work with them in PrPro CS4?
By tomchook in forum Newbie / General discussionsReplies: 7Last Post: 13th Apr 2012, 11:02 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
MPEG2-->MPEG2 Crop + Resize
By wincrazy in forum Newbie / General discussionsReplies: 26Last Post: 24th Jan 2009, 01:30 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 06:49
