I have about 6 avi movies about 700mb each, but cannot join them in VirtualDub and also VirtualDubMod as it says they are different sizes How can I get them all the same size. As I notice 1 is 448x336 and another is 464x352, & 496x338 etc![]()
You have two choices.
Either load them into a NLE where resolution isn't an issue, or choose a single size and re-encode all the other clips until they match up. When doing this, make sure that everything else matches as well - framerate, audio format etc.Read my blog here.
NLE : Non-Linear Editor
Vegas, Premiere Pro, Media Studio Pro, VideoStudio etc.
These are pretty much resolution independent. The better ones will allow you to resize each clip individually until you get a fit.
Otherwise, load each into virtualdub in turn, resize and save to a lossless codec (Lagarith, Huffyuv etc), then join and re-encode to something smaller.Read my blog here.
ok decided to go for easy option above thanks
Question about Joining movies.
By eliqush in forum Video ConversionReplies: 4Last Post: 21st Jun 2009, 14:40 -
Joining Image and Two Separate QuickTime Movies
By lindylex in forum EditingReplies: 2Last Post: 13th Mar 2008, 13:30 -
joining up .mpg movies
By natty in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2008, 07:14 -
joining avi's
By php111 in forum EditingReplies: 15Last Post: 5th Aug 2007, 11:05 -
joining 2 avi movies
By php111 in forum Newbie / General discussionsReplies: 25Last Post: 2nd Aug 2007, 19:30
