i'm using DVDfab Platinum 3.1.5.0 and on the screen it gives me the option to remove DTS audio. what is DTS audio and does it make a difference if i remove it or let it stay. which is better?
	AC3 audio is universally playable. If you don't have an AV amplifier then your player will down-convert it to stereo analogue.
 DTS is arguably superior in sound quality, however it requires (in most cases) a separate decoding AV amplifier connected via an optical or coax digital link. It will not be down-sampled if you don't have one, so you get no audio at all if you cannot decode it. And it takes up 60 - 90 % more space than a 5.1 channel AC3 track.
 If you have the kit, then you can keep it if you want. If you don't have the kit, or space is at a premium, take the AC3 5.1 instead.Read my blog here.
	I agree with guns1inger - if you have the space keep the dts AND the ac3. DTS is generally better audio at a higher bitrate.
 BUT if you are shrinking the disc to fit a single layer then remove the dts so you can preserve more picture quality while transcoding.
 Also - do not do a dts audio only disc. It will most likely work on the majority of dvd players but you will only have sound through an amplifier that supports dts audio. It will not pipe through just the tv alone - unless it has dts decoder in it and those are extremely rare if one exists at all.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
  How i can convert the dts-es or dts-ex 6.1 into dts core 5.1By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 17:25
  MKV files with Audio in DTS need to convert audio to AC3By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 09:17
  hd audio or dolby/dtsBy lordhutt in forum Blu-ray RippingReplies: 3Last Post: 11th Feb 2011, 00:00
  encoding with DTS audio stream - Audio not found in AutoGKBy extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 17:42
  DTS audioBy Gary Barker in forum Authoring (DVD)Replies: 3Last Post: 30th Nov 2007, 11:22
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
