After reading the various posts, it was claimed that the 2006 cards could still capture PAL-60. The card comes with v9.12 of ATI MMC and there is a tv setting for PAL-60.
However, when I try to play/capture a NTSC video - using scart from the VCR and then RCA to the ATI connectors - I get a picture and in colour but it is very un-steady and the visual effect is like the vertical hold is way out as there is a black bar 2/3rds way down the screen and then some more of the picture which rips at the top and along the edge.
Standard PAL videos are ok in the the ATI.
Has anyone had this problem or offer some suggestions.
Thanks.
I would expect the ati want's you to capture it as nstc for nstc , and not as pal .
That vertical hold , and other anomalies , indicate you need to switch the capture program over for nstc capture .
Convert the frame rate to pal later . -
After doing some more 'research' it seems that I am not alone with this issue.
Seems like that older cards with other chips and agp were ok but not newer models.
And it's hardly a high priority matter for ATI to fix.
ATI AIW 2006 PCIE -- do I need the breakout box?
By robjv1 in forum Capturing and VCRReplies: 8Last Post: 29th Jul 2011, 10:44 -
My TV Caps have Low Audio Volume and Hiss - ATI AIW 2006 PCIE
By somebodeez in forum Capturing and VCRReplies: 16Last Post: 26th Apr 2008, 08:08 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11 -
ATI Radeon HD 2600 XT 512 Mo PCI-Express for HDTV, ENCODING,EDITING
By leguerisseur in forum DVB / IPTVReplies: 0Last Post: 21st Sep 2007, 08:30 -
Anyone know if the ATI All in Wonder 2006 Edition can capture PAL 60?
By MarksmanR in forum Capturing and VCRReplies: 5Last Post: 29th Jul 2007, 08:10
