anyone know where i can get a easy guide to useing proxys. ive read a couple but cant figure it out
what kind ? socks , cgi or http? for web use ? or newsgroup or irc or ftp ?
a google search will prob. find you 100's of guides -- though a lot of proxies go down all the time as well as not being anon...
you might want to try something like proxyway"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
