I am trying to weigh up whether to buy an Archos 404 with a DVR stand, or an Archos AV 500. The primary use for the device will be to record from TV and also to use it as a playback device on the television. I was just wondering whether there would be a difference in quality between the two units? The Archos AV 500 seems to offer an all-in-one solution, whereas the 404 would be standalone and would use the DVR stand to record as a passthrough device. Would this affect the quality at all? I can get about the same deal on both and am trying to decide whether it would be better to get the 404 since it is two components (making it cheaper to replace if one part breaks) or whether I should just get the AV 500 and keep things a little simpler.
Thanks for any help!
Results 1 to 1 of 1
Video files for an Archos AV 500
By merryperson69 in forum Newbie / General discussionsReplies: 1Last Post: 31st Dec 2009, 07:08 -
[Archos 605] transform from 720p.HD.DVDRip.XviD.AC3 to Archos format ?
By birdwing in forum Portable VideoReplies: 2Last Post: 6th Nov 2009, 00:41 -
Anyone using the 2000mAh Hi-Cap Battery for the Archos 404?
By capman21 in forum Portable VideoReplies: 0Last Post: 23rd Jul 2008, 19:36 -
Anyone have a Archos 404 or 504?
By capman21 in forum Portable VideoReplies: 1Last Post: 11th May 2008, 22:45 -
archos 404 bullet sample clips
By nivek_nayr in forum Portable VideoReplies: 0Last Post: 20th Feb 2008, 02:36
