Hey again. I posted another topic a while back asking about MovieFactory, and I've purchased it between then and now. It works great for the most part. The only problems I'm having are with the menus and playback on DVD players, but oddly, they work fine on computers.
When I preview the menu before burning the DVD, it works fine, so then I burn the DVD. Once it's finished, I test it out on my computer and it works perfectly, but for some reason, when I play the DVD in a DVD player, the menu doesn't work right. It looks right (images, text, etc. are where they should be), but I can't select anything with the remote. Another issue is that I can't skip between chapters when watching the clips on the DVD.
Does anyone know what's going on?
Do you mean the Button Highlights are not working
What is the exact version number of the software you have
Yes, the highlight buttons aren't working, so that's probably why it seems like I can't select anything on the menu, but I also can't skip from chapter to chapter while watching clips from the DVD. And I'm using Ulead DVD MovieFactory version 6.
Oh yeah, and the highlight buttons work when the DVD plays on the computer, oddly. I still can't skip between chapters when watching the DVD on my PC though. Can't figure out what's going on... it's really weird ^^;; -
What is the exact version in Help/About (6.xxx.xxx, etc...)Originally Posted by cheeseandcrackers
Also, are you talking about CHAPTERS as in a video clip that has multiple chapter marks along the clip (go-t0 points of a video clip), or do you have multiple separate video clips that you added to your project
I have MovieFactory 6, and installed Patch 1, and have the same "menu highlight select not visible problem". The menu select highlights aren't visible when playing the DVD on Panasonic A120, but are visible on Philips 724.
I never had this problem with MovieFactory 3SE. Could someone help please? Thank you. -
It seems like maybe MovieFactory 6 Patch 2 fixes the menu highlight select problem. I made a DVD using a MF6 template after installing Patch 2, and the highlight select worked fine on my Panasonic A120 DVD player.
Ulead Moviefactory 6 transition Help
By musickerns in forum Newbie / General discussionsReplies: 2Last Post: 18th Jun 2011, 13:26 -
Ulead Moviefactory
By acw in forum Newbie / General discussionsReplies: 10Last Post: 24th May 2009, 00:51 -
Ulead DVD MovieFactory 6 Plus Menu Option Question
By SCDVD in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 13:42 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 10:43 -
Questions about Ulead DVD MovieFactory 6
By cheeseandcrackers in forum Authoring (DVD)Replies: 5Last Post: 18th Jun 2007, 10:46
