I used DVD decryptor, then DVD shrink. I set it up to burn with Nero. I even check boxs to make my DVD+R compatible. I get this message (sorry to make it so long, can someone please help and identify my problem):
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
Nero API version: 6.6.0.12
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 0, 12c
Recorder: <HP DVD Writer 200j> Version: 1.36 - HA 1 TA 0 - 6.6.0.12
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SV8004H atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HP DVD Writer 200j atapi Port 1 ID 0 DMA: On
CdRomPeripheral : MITSUMI CD-ROM FX48++W atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
HP DVD Writer 200j E: CDRom0
MITSUMI CD-ROM FX48++W F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 195MB (200204kB)
Memory in use : 61 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
3.8.2007
NeroAPI
7:05:27 PM #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
7:05:27 PM #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
7:05:27 PM #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
7:05:31 PM #4 Text 0 File Reader.cpp, Line 127
Reader running
7:05:31 PM #5 Text 0 File Writer.cpp, Line 122
Writer HP DVD Writer 200j running
7:05:31 PM #6 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
7:05:31 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3293
First writeable address = 0 (0x00000000)
7:05:32 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3293
7:05:32 PM #9 Text 0 File Burncd.cpp, Line 3153
Turn on Disc-At-Once, using DVD media
7:08:11 PM #10 Text 0 File DlgWaitCD.cpp, Line 260
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2286127 (508:01.52, 4465MB)
7:08:11 PM #11 Text 0 File DlgWaitCD.cpp, Line 272
Write in overburning mode: NO
7:08:11 PM #12 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: HP DVD Writer 200j, Media type: DVD+R
7:08:11 PM #13 Text 0 File DlgWaitCD.cpp, Line 438
>>> Protocol of DlgWaitCD activities: <<<
Compilation cannot be written on that medium type.
(Medium in drive: DVD-ROM. Medium required by compilation: DVD+R/RW.)
7:08:11 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2286128 (2286128) = #2286128/508:1.53
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286128 blocks [HP DVD Writer 200j]
7:08:11 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [HP DVD Writer 200j] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681990144, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2286128 | lead-out | 1 | 0x41 | 0x00
7:08:14 PM #16 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
7:08:14 PM #17 Text 0 File Burncd.cpp, Line 4037
Cache writing successful.
7:08:14 PM #18 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
7:08:14 PM #19 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 2.4x (3,324 KB/s)
7:08:14 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
7:08:14 PM #21 SCSI -1066 File Cdrdrv.cpp, Line 1182
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0A570600
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0C
0x00 0x00 0x00 0x00 0x24 0x00
7:08:14 PM #22 SCSI -1066 File Cdrdrv.cpp, Line 1182
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xF9 0x15 0x01 0xFF 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
7:08:14 PM #23 Text 0 File DVDR.cpp, Line 5601
Drive: HP DVD Writer 200j
Book Type request [gen]: DVD-ROM, write to EEPROM
Changing the Book Type was finished successfully, return code 0
7:08:14 PM #24 CDR -1211 File DVDR.cpp, Line 4768
Book Type set to: DVD-ROM
7:08:14 PM #25 Text 0 File DVDPlusRW.cpp, Line 648
Start write address at LBA 0
DVD high compatibility mode: Yes
7:10:41 PM #26 SCSI -400 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x00B90000
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x91
Sense Qual: 0xC1
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0C
0x00 0x00 0x00 0x00 0x91 0xC1
7:10:41 PM #27 CDR -400 File Writer.cpp, Line 311
Unspecified target error
7:10:41 PM #28 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
7:10:41 PM #29 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
7:10:43 PM #30 Phase 127 File APIProgress.cpp, Line 276
Generating DVD high compatibility borders
7:10:45 PM #31 Phase 129 File APIProgress.cpp, Line 276
Generating DVD borders completed successfully
7:10:45 PM #32 SCSI -1066 File Cdrdrv.cpp, Line 1182
Sense Code: 0x24
Sense Qual: 0x00
7:10:45 PM #33 Text 0 File DVDR.cpp, Line 5601
7:10:45 PM #34 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 2.4x (3,324 KB/s)
7:10:45 PM #35 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
7:10:45 PM #36 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'WNASPINT.DLL': Ver=V1.17, size=55808 bytes, created 9/5/2002 8:50:38 AM
File 'Drivers\PXHELP20.SYS': Ver=2.02.50a, size=17136 bytes, created 1/15/2005 9:12:18 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\InCDfs.SYS': Ver=4, 3, 0, 5, size=93440 bytes, created 9/13/2004 12:54:06 PM (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDpass.SYS': Ver=4, 3, 0, 5, size=28672 bytes, created 9/13/2004 12:54:46 PM (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDrec.SYS': Ver=4, 3, 0, 5, size=7680 bytes, created 9/13/2004 12:58:10 PM (InCD4 driver for win NT/2K/XP)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Results 1 to 9 of 9
That's usually a communication error. You seem to have DMA enabled, but that's one cause. For lack of any other ideas, you might check to see if anything is running in the background. Some programs like anti-virus can interfere with the data flow.HA-Status 0x00 (0x00, OK)
And I would always try a different brand of DVD media, just in case the problem is related to that. If it was a external USB writer, that would be a more common error.
Lastly, try burning the VIDEO_TS folder with ImgBurn in 'Build' mode. It generally does a better job than Nero, and worst case, you will have more data is the burn fails.
And is this a new problem and everything worked before? Or have you made any recent changes in the system?
Someone else may spot something else in the log and have a better idea.
And welcome to our forums.
Untick burn with Nero and set DVDShrink to save as an .ISO to burn with DVDDecrypter. This will help determine if it's Nero's fault. Also note the last version of Nero 6 no longer plays well with DVDShrink. Although it's kind of confusing what version you have.I used DVD decryptor, then DVD shrink. I set it up to burn with Nero.
Internal Version: 6, 6, 0, 12c -
Ok So it was a no go with nero. I use ImgBurn and I got an error (I'll past it right now) and DVD Decryptor doesn't show any errors, but it never gets past "WRITING LEADIN"
Any HELP from here?!?!?! Thanks peeps!
I 12:49:41 ImgBurn Version 2.3.2.0 started!
I 12:49:41 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 2)
I 12:49:41 Total Physical Memory: 523,760 KB - Available: 40,768 KB
W 12:49:41 Drive D:\ (FAT32) does not support single files > 4 GB in size.
I 12:49:41 Initialising SPTI...
I 12:49:41 Searching for SCSI / ATAPI devices...
I 12:49:42 Found 1 CD-ROM and 1 DVD+RW!
I 13:37:00 Operation Started!
I 13:37:00 Source File: C:\Documents and Settings\Owner\My Documents\Anthony's Folder\SHOOTER.iso
I 13:37:00 Source File Sectors: 2,285,868 (MODE1/2048)
I 13:37:00 Source File Size: 4,681,457,664 bytes
I 13:37:00 Source File Volume Identifier: SHOOTER_AC_43
I 13:37:00 Source File Implementation Identifier: DVD Shrink
I 13:37:00 Source File File System(s): ISO9660, UDF (1.02)
I 13:37:00 Destination Device: [1:0:0] HP DVD Writer 200j 1.36 (E
(ATA)
I 13:37:00 Destination Media Type: DVD+R (Speeds: 2x, 2.4x)
I 13:37:00 Destination Media Sectors: 2,295,104
I 13:37:00 Write Mode: DVD
I 13:37:00 Write Type: DAO
I 13:37:00 Write Speed: MAX
I 13:37:00 Link Size: Auto
I 13:37:00 Test Mode: No
I 13:37:00 BURN-Proof: Enabled
I 13:37:07 Filling Buffer... (20 MB)
I 13:37:07 Writing LeadIn...
W 13:39:30 Failed to Write Sectors 0 - 31 - Unknown (0x91, 0xC1)
W 13:39:30 Retrying (1 of 20)...
W 13:40:37 Retry Failed - Unknown (0x91, 0xC1)
W 13:40:37 Retrying (2 of 20)...
W 13:41:49 Retry Failed - Unknown (0x91, 0xC1)
W 13:41:49 Retrying (3 of 20)...
W 13:43:17 Retry Failed - Unknown (0x91, 0xC1)
W 13:43:17 Retrying (4 of 20)...
W 13:45:01 Retry Failed - Unknown (0x91, 0xC1)
W 13:45:01 Retrying (5 of 20)...
W 13:46:50 Retry Failed - Unknown (0x91, 0xC1)
W 13:46:50 Retrying (6 of 20)...
W 13:48:48 Retry Failed - Unknown (0x91, 0xC1)
W 13:48:48 Retrying (7 of 20)...
W 13:51:12 Retry Failed - Unknown (0x91, 0xC1)
W 13:51:12 Retrying (8 of 20)...
W 13:54:30 Retry Failed - Unknown (0x91, 0xC1)
W 13:54:30 Retrying (9 of 20)...
W 13:57:46 Retry Failed - Unknown (0x91, 0xC1)
W 13:57:46 Retrying (10 of 20)...
W 14:02:10 Retry Failed - Power Calibration Area Error
W 14:02:10 Retrying (11 of 20)...
W 14:07:44 Retry Failed - Power Calibration Area Error
W 14:07:44 Retrying (12 of 20)...
W 14:13:26 Retry Failed - Unknown (0x91, 0xC1)
W 14:13:26 Retrying (13 of 20)...
W 14:18:14 Retry Failed - Power Calibration Area Error
W 14:18:14 Retrying (14 of 20)...
W 14:23:22 Retry Failed - Power Calibration Area Error
W 14:23:22 Retrying (15 of 20)...
W 14:28:13 Retry Failed - Unknown (0x91, 0xC1)
W 14:28:13 Retrying (16 of 20)...
W 14:33:24 Retry Failed - Power Calibration Area Error
W 14:33:24 Retrying (17 of 20)...
W 14:38:00 Retry Failed - Power Calibration Area Error
W 14:38:00 Retrying (18 of 20)...
W 14:42:21 Retry Failed - Power Calibration Area Error
W 14:42:21 Retrying (19 of 20)...
W 14:46:40 Retry Failed - Power Calibration Area Error
W 14:46:40 Retrying (20 of 20)...
W 14:51:00 Retry Failed - Power Calibration Area Error
E 15:56:59 Failed to Write Sectors 0 - 31 - Unknown (0x91, 0xC1)
I 15:56:59 Synchronising Cache...
I 15:57:00 Closing Track...
I 15:57:01 Finalising Disc...
E 15:57:02 Failed to Write Image!
E 15:57:02 Operation Failed! - Duration: 02:20:02 -
Does ImgBurn correctly id the discs? What are they?
Seems to be a rather old drive that wasn't held in high regard. New OEM drives are dirt cheap.
http://club.cdfreaks.com/showthread.php?t=139421 -
Well, that one is mainly a 'power calibration error'. When a burner starts to write to a DVD disc, it uses a special area towards the center of the DVD. It does a trail burn to set the speed and power levels of the DVD burner for the actual burn.
When this fails, it can be for several reasons:
Most commonly is the burner does not have a burn strategy for the media you are using. You can try different media or update the firmware of the burner.
Other causes are a power supply that doesn't supply enough power to the burner to do the calibration. This is more common with external drives. You can unplug other drives to lessen the PS load for a test.
Last and least likely is a failing burner.
But anything is possible. You would probably get this error on all brands of media, though. Some HP burners don't have a good reputation, so still something to keep in mind.
But media is the easiest and the cheapest thing to change. I would try some DVD - media, and use a different brand. One item I couldn't find in the Nero log is the media code that identifies the media. But I may have missed it. That's a little unusual and could also point to a media problem. -
Does anyone else see a problem with using DVDDecryptor with a movie that was released only recently(IF the movie title is correct - Shooter)?
Also:
HP drives....I recall reading several horror stories about those here.
Destination Media Type: DVD+R (Speeds: 2x, 2.4x) - Haven't seen those speeds for quite a while....how old are these discs?
Write Speed: MAX - always a bad idea. -
Originally Posted by hech54
the movie he's trying to backup is a newly released dvd movie called, "SHOOTER". Can't just use DVD DECRYPTER because it's no longer updated. Newer copy encryptions are in the newer released dvd movies so you'll need to use DVDFAB DECRYPTER. qwazi in order to rip the movie files use the latest version of DVD FAB DECRYPTER then use DVD SHRINK. Then burn with NERO or IMHO use IMGBURN which is better than NERO.
http://www.dvdfab.com/free.htm
(Download the one that says, "Download 3.1.5.6 Beta (Aug 7, 2007)")
Also as suggested use better dvd media than those 2x-2.4x speed discs that you have & don't burn at the maximum speed, burn at 8x - 12x speed depending how fast your HP dvd burner is. Buy some VERBATIM dvd media.
Error messages burning data DVD using Nero version 6
By craigsb in forum ComputerReplies: 6Last Post: 27th Oct 2011, 10:12 -
DVD error while burning in NERO 7
By coinsdrop in forum Newbie / General discussionsReplies: 19Last Post: 22nd Apr 2009, 11:46 -
Nero 9.2.5.0 - Can't burn anymore (error message enclosed)
By rock_king_my in forum Newbie / General discussionsReplies: 9Last Post: 14th Apr 2009, 11:02 -
Error, after burning a dvd with nero
By Remyisme in forum Newbie / General discussionsReplies: 13Last Post: 27th Sep 2008, 03:11 -
When burning DVD error message about AC3 files keeps coming up
By blueedlilly in forum DVD RippingReplies: 7Last Post: 13th Feb 2008, 12:23
