I have a joycoder pc-330 portable dvr it records from tv and anything else with a video output. What i am wanting to do is strore my video files on this thing, my problem is everything that is recorded on the device is in avi format 320X240 with a 256kbps bit rate. now i can take from from device and do anything i want to with the files, same as with all my other video files of which i own. Now i have MovAvi video converter 5.5, which pretty much allows u to do anything converting wise with your files you can think of, if you know what your doing???.which is where my problem is..lol.. i can convert videos for my PSP, my pocket PC, my ipod, even my girlfreinds cell phone. i can not for the life of me convert any of my files to play on this device.......i can convert the files to match format/avi,audio/pcm,and deminsion/320X240, but i can not get my bitrate to come out 256kbps????? any help and or advice, i dont pretend to know what im doing im just figureing it out as i go, but this one has me stummped. thank you
Yea my software has a calculator, my problem is understanding what to do with it. No matter what ive tried so far doesnt seem to work, my files keeps coming out 1411kbps. And of course its been a couple days and they havent answered any of my tech questions.
1411kbps is cd wav standard for audio I believe. You might have a default setting clicked on by mistake somewhere. See if you have a setting for custom controls or some terminology like that.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Don't ask me how I found this out but I was messing around the other day and I noticed that I could get different bitrates on PCM WAV files using Goldwave.
This is a WAV sample at 16KHz and saved as 8 bit stereo and you can see that it has a bitrate of 256kbps. You get the same result by saving as 16 bit mono.If in doubt, Google it. -
8 bits per sample
2 channels
16,000 samples per second
8 * 2 * 16,000 = 256,000
But this is your audio. You need to make your video 256kbps MPEG 4 ASP.
DTS 15xx kbps to DTS 768 kbps and tsMuxeR question.
By Jared_ in forum AudioReplies: 0Last Post: 1st Jun 2009, 09:46 -
128 kbps to 96 kbps MP3 - big difference?
By joshua4 in forum AudioReplies: 12Last Post: 24th Oct 2008, 14:11 -
why 320 kbps mp3 have less vol compare to 128 kbps files?
By sumeshkri in forum AudioReplies: 4Last Post: 27th Sep 2008, 07:57 -
iPod classic limit for AAC NOT 160 kbps! Supports 320 kbps!
By FallenAngelII in forum AudioReplies: 1Last Post: 29th Dec 2007, 12:14 -
Convert .ac3 (384 Kbps) to Dolby 5.1 (448 Kbps) ????
By christopheramos in forum AudioReplies: 6Last Post: 11th Jul 2007, 00:35
