i have 250 AVI movies about 700M each and i need to comprewss them to a small format without loosing teh quality
i tried DIVX convert but took 12h to do 5 files thats way to long, is there anyting else i can use or even a better then divx format
P4 3.2
2G ram
4 750G HDD
2 320 HDD
2 WD 75G Raptors
WHy does when ever i run Divx concerter my cpu go to 100% is there a leek in the software
Every encoder should be using close to 100% or it would be ineffecient. And even slower.
If you are wanting to do something else on the computer, then you can slow it down to 50% and have it take twice as long.
If you reduce the bitrate or quality of the encode, it will go quicker. -
If you want to do something else on the computer while running Divx Converter use Task Manager to set Divx Converter's priority to Low (or it may have it's own process priority setting, I don't know, I don't use it).
Try using faster settings in Divx. For example, setting Encoding Mode to Balanced may be several times faster than Extreme or Insane. The quality won't be that much lower.
Getting right DivX format for Blackberry ... ?
By Diana (Cda) in forum Video ConversionReplies: 5Last Post: 30th May 2010, 14:25 -
How to watch a .avi file in a dvd player that support divx format?
By albi123 in forum MacReplies: 5Last Post: 18th Feb 2010, 08:53 -
What's the best format DivX or Xvid I can get?
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 19th Jan 2009, 14:59 -
a good tool for converting avi or divx to the dvd vob format?
By extent in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2009, 13:37 -
Better format to encode to: MPEG2 or DivX/AVI?
By Grunberg in forum Video ConversionReplies: 15Last Post: 15th Feb 2008, 08:29
