Hello,
I am trying to convert an audio track from 25fps to 23.976fps so i can add it to one HD 1080p mkv file.
I first got the audio track from a dvd.
The total time of the audio track is 1:26:52
The total time of the HD movie is 1:30:36
I am using BeSweet v1.4 with the following Command
"C:\BeSweet GUI\BeSweetv1.4\BeSweet.exe" -core( -input "Path to my audio track\Original_DVD_Audio_Track.ac3" -output "Path to my audio track\Original_DVD_Audio_Track--NEW.ac3" -logfilea "C:\BeSweet GUI\BeSweet.log" ) -azid( -c normal -g 0.95 -L -3db ) -ota( -r 25000 23976) -ssrc( --rate 48000 ) -ac3enc( -b 640 -6ch )
Then i use mkvmerge to mux it to my HD video.
But I still get the audio out of synch with the video by 2000ms. I measure the above delay using a stopwatch.
Also the sound is not as loud and clear as the original english audio track ac3 5.1 448 kbps
How can i fix these?
I aslo change the Sampling rate to 48000Hz on the SSRC tab
and
on the AC3 / OGG / PCM i change the bidrate to 640kbps and check the Create 5.1 AC3
i manage to fully synch this but i dont know what i did was correct or just a lucky move.
anyway i put a Set Delay to 5000ms on the BeSweet command and then i add another 1000ms delay on the mkvmerge delay of the audio.
I still have some noise in my new audio track tho so any help on that will be greatly appriciated.
Quick easy way to convert DVD subs from 25fps to 23.976fps?
By nick1977 in forum SubtitleReplies: 19Last Post: 22nd Feb 2015, 18:36 -
25fps-source Ac3 to 23.976fps
By Lastman369 in forum AudioReplies: 47Last Post: 26th Sep 2014, 03:19 -
[MKV] 25fps to 23.976fps? Tried and failed. Help!
By lag in forum Newbie / General discussionsReplies: 15Last Post: 20th Aug 2014, 13:27 -
Converting 25fps XVID to 29.97 MPEG2
By dkrajisnik in forum Video ConversionReplies: 6Last Post: 21st Sep 2010, 15:46 -
25fps to 23.976fps
By Charmer in forum AudioReplies: 19Last Post: 8th Aug 2009, 11:41
