hi...i bought da dvr-9300hx of bidtv a couple months ago and jus cant get the sound to work...i tryed via scart, clinch cables and jus bought 5.1 surround speakers nothin workesjavascript:emoticon('')
Evil or Very Mad
i was wondering if u could give me any solutions and also i have a homechoice (tiscali tv) box and was wondering if i am able to connect it to my dvd recorder via scart and get it to work
thanx
Have not had a lot of experience with scart connections but I have always seen them work ok
I notice that you purchased this unit from bidtv. This is a UK auction somewhat like ebay.
Can I assume by the post that it is used and has never worked. It might be that the unit is defective. I have noticed that a number of units purchased, used, do not work correctly and have lead users to assume that its the connections or other things at fault.
Can you connect the unit direct to the TV and if it doesn’t work, connect another unit in the same manner.
I should think that the recorder/player should play a commercial DVD, sound and picture. If the Unit Output is connected direct to the TV Input and the proper source selected . -
Go to the audio set up page and fiddle about there .. also try connecting it to an external amplifier using phono plugs (white and red).. and of course swap around with the scart cables .. they can work loose or even sit loosely in the sockets.. I have to admit, I wouldn't put yamada in the top tier of Mfrs (more like the bargain basement).. try playing an audio Cd on the unit, or an mp3 CD
The electronic components of the power part adopted a lot of Rubycons.
yamada DVR 9000 won't start :(
By mwg in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Jan 2010, 09:24 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Yamada PVR-9300HX DVD+R/RW problems
By Verso in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Oct 2008, 18:13 -
how to record from the HDD to a DVD+RW disk, using a Yamada DVR-9300HX
By The Muddler in forum DVD & Blu-ray PlayersReplies: 7Last Post: 1st Aug 2007, 14:00
