Hi...
Based on input from people here, about a year ago I purchased a JVC 9911 SVHS and JVC MH30 DVD recorder. Circumstances arose and I put my VHS conversion project on hold.
I do have two questions. First and foremost, I notice the audio is very low on my final DVDs. Even stuff that's right from the DVD recorder's hard drive, and not a VHS conversion. Is there a way to boost the sound?
Second, and a very generic question, is this still an ideal setup or is it outdated?
Thanks for any advice.
Hi, sorry but the sound problems could be on the JVC MH30 this link gives details
http://www.cippico.com/bbs/viewtopic.php?t=7
Are you sure it's not bad sound cables are you a scart user, or seperate svid/phono plugs.
If scart make sure their all in properly, wiggle 'em in abit.
Does the HR-S9911 have audio level controls? you'll have to check the manual.
Try using any other VCR you have just to be sure.
Is it slightly quiter or seriously quiter, if so it could be a fault like in the link. Hope you can sort it.
Need suggestions on JVC DR-MH30
By iamnotamused in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Sep 2010, 03:04 -
JVC VCR 9911 on ebay f0r $10 !!!!
By victoriabears in forum Newbie / General discussionsReplies: 5Last Post: 6th Jul 2009, 16:31 -
Panny 1980 vs JVC 9911 vs ???; what's your preference and why?
By videobruce in forum Newbie / General discussionsReplies: 5Last Post: 6th Jul 2009, 14:15 -
JVC DR-MH30 make or restore hd particion
By danilo_nop in forum DVD & Blu-ray RecordersReplies: 0Last Post: 29th Feb 2008, 04:01 -
JVC DR-MH30 Broke I Think Update.
By hutch642 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Dec 2007, 09:43
