I am currently looking for a card that has:
-RCA Inputs
-No special software, as in, can be used with a program such as VirtualDub.
-Under $90
I do not care about watching tv, that is what I have a television for.
So far, I have found this:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2905645&CatId=1425
But I am not sure if that meets my needs.
If somebody knows of a good card for me or knows more information about the ImpactVCB could you please post?
I am also open to USB alternatives, such as the dazzle premium. But again, it can't have to use special software.
Edit: Would something like this work if I join the audio from the RCA cable and plugged it into mic in? I have an integrated sound card:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2291102&CatId=1425
The sound card is a Yamaha AC-XG
Throw in some pc specs for analysis as to suitability .
The dvd ezymaker card is not "top of the class" from avermedia , but a safe option at a very good price , and you can bug me for help with it ... it is almost flawless to install and setup ... done the correct way first .
With the correct setup , you can capture from anything ... xbox360 , ps3 , other pc screen outputs .
For a little more , you can get the next unit up which includes dvb recording .
Best caps are from the supplied software or nero express .
With a very good setup :
Windows movie maker can cap hours in wmv .
Windows media encoder can stream input to web .
They even have a free version of the neo product :
http://www.bestfreewaredownload.com/freeware/k-dvd-authoring-t-free-neodvd-video-8-lp-...-pgambiii.html
The new version of virtualdub now works with the device ... not perfect yet , but works to a point .
Audio gose to linein on pc sond device ... do not use the audio input on the card ... it cause's interference ... snow / static look , and results will not be the clearest .
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Good HDMI or Component Capture Card for Game Consoles?
By jargus in forum Capturing and VCRReplies: 18Last Post: 26th Jan 2011, 10:37 -
A good Mic, Capture Card, and Video Editing Software.
By xSyndromex in forum Newbie / General discussionsReplies: 8Last Post: 18th Jan 2010, 14:38 -
Game console -> PC -> monitor ... current good card?
By Asterra in forum Capturing and VCRReplies: 2Last Post: 10th Aug 2009, 08:31 -
My capture card loses signal during some video game scene transitions
By Nintendo Fan in forum Capturing and VCRReplies: 1Last Post: 21st Mar 2009, 11:51
