  1. Hi ,
    Trying to fix some sd and hd footage that was created for a website for a directors reel.
    The following settings were applied to the footage -
    Format - Sorrenson Video 3- 400x300, millions,aac,stereo,44100hrz
    movie fps - 29.97
    data size - 27.86
    data rate 1.72mbs/sec
    duration 2.15
    Now in my opinion i would have used the H.264 and had the data rate between 400-600
    Can anyone tell me what they would do to this -
    The videos load horribly slow on some connections and slower computers
    thanks
  2. no one has encoded quicktimes for the web?
    any help appreciated
  3. Member Soopafresh's Avatar
    Jan 2004
    You should use the original footage instead of trying to re-compress the Sorensen encoded video.
    400x300 is a strange file size and won't compress effectively. Change the dimensions to 400x304. Try 600-700kbps for the bit rate.
  4. yeah i wanna get hold of the origonal footage first to work from -
    So would you advise the H237 codec over sorenson 3?
    heres the website so you can see the issues -
    http://www.dorondp.com/
