Hello All,
I just picked up a second Philips DVP 5960/37 and it doesn't read any sort of inserted discs. I've tried commercially produced DVDs, home made DVD-Rs, DivX, CD-Rs and factory made CD audio discs. The machine will not read any of them. When you insert a disc, it makes a brief mechanical sound but not the typical spinning or whirring sound. Then, after a few moments it reads No Disc on the display. I've set the setup screens the same as on my other DVP5960 that does play discs, but no luck. It does however, play DivX files when connected to a hard drive via USB the way my other DVP5960 does. Could it just have a bad drive? I haven't called Philips yet. It is after hours right now. Any suggestions before I call them? Thanks.
Mike
Philips DVDR3576H/37 - Burned Discs Won't Play in Xbox, PC DVD Drive
By jbd5010 in forum Capturing and VCRReplies: 18Last Post: 20th Mar 2011, 04:11 -
philips dvp5960
By tonie in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Sep 2008, 15:58 -
Philips DVP5960 Help
By clubfoot in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Sep 2007, 06:39 -
pioneer 510H will burn but won't read unfinalized discs
By nixie in forum DVD & Blu-ray RecordersReplies: 10Last Post: 6th Jun 2007, 19:25 -
Philips 20X SPD2413BD won't read 8cm DVD-R discs
By nlec in forum DVD & Blu-ray WritersReplies: 1Last Post: 5th Jun 2007, 12:03
