    Jun 2007
    New Zealand
    I have an HP Compaq 6710b Notebook with a 15.4" diagonal screen, (1280x800 pixel). I want to attach it via its VGA connector to my Epson EMP-S3 projector which has a native format of 800:600. I want to keep the projector set for 16:9 mode and show a stretched version of my PC screen that fills it.
    For playing DVDs I can do this conversion using KMPlayer and it works perfectly. There is no additional hardware required so the conversion must be computed. Is there a means of doing the same thing for the PC's screen as well? If so where can I obtain the software?
    Regards
    Colin
    Colin Dillicar
    Colmin Associates
    Auckland New Zealand 0610
    +64 9 834 4040
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    There is no "conversion" that takes place when outputting the desktop...hence no software. You have to adjust your desktop settings (resolution and refresh rate) to fit your projector.
    Google is your Friend
    Jun 2007
    New Zealand
    Hi Krispy,
    Thanks for your reply, I've managed to strike a compromise as you suggest. I was just wanting a solution that didn't involve moving the projector optics but accept that it's not that simple.
    Cheers
    Colin
    Colin Dillicar
    Colmin Associates
    +64 9 834 4040
    Feb 2003
    I don't think that's what Krispy Kritter is talking about in their reply. They're talking about adjusting the settings on your video card (resolution, refresh rate, etc) to more properly match the projector.
    Jun 2007
    New Zealand
    Sorry, I may have confused the issue a little.
    I've changed my Desktop settings and it almost does what I want but I still need to change the Wide-Screen adjustment to accommodate the picture height within the projection screen area (which is curtained off).
    I'ts not so bad to worry anymore and I accept that it's a physical issue.
    Colin Dillicar
    Colmin Associates
    +64 9 834 4040
