Hey all,
I just flashed my Pioneer 112D to 112L. Getting a power calibration error now when trying to burn a disc.
Solutions?
Results 1 to 9 of 9
What firmware did you use to crossflash your 112D to the 112L drive? Did you use "THE DANGEROUS BROTHER'S" FIRMWARE?
I used the Buffalo 112L 8.21 firmware package following all directions. Koba “Firmware and utility for A12J&112L.zip
Using Nero to burn with. Fujifilm media. New DVD burner.
Just started this after the flash. -
You should have used "THE DANGEROUS BROTHER'S" firmware which enables REGION FREE. All you have achieved from the buffalo firmware is enabling bitsetting to dvdrom for DVD+R media. This is why you are having the region counter problems.
Download the appropriate firmware from "THE DANGEROUS BROTHER'S website.
http://tdb.rpc1.org/
Remember now that you've already crossflashed your drive so now your PIONEER warranty is now void. -
The Dangerous Bros site only has to 8.06. The Koba .zip flashes from 112D to 112L 8.06 then to 8.21. Or are there some kind of differences between the Koba file and the DB files for the same firmware version?
Not concerned with region free.
Wondering if the L configuration doesn't find my media satisfactory, tho I've never had a problem with it.
>>>>Remember now that you've already crossflashed your drive so now your PIONEER warranty is now void. <<<<<<
For no more than the $39 or so the drive cost, I'll risk it. -
You edited your other post and deleted the part about region counter.Originally Posted by Trailryder
Very
Post your confusing question at the PIONEER forum at Cdfreaks.com.
Sometimes power calibration errors can be from trying to burn a disc at a higher speed than the media can handle. -
Sorry about that Budz. I appreciate your reply. Just after posting the region question I figured I should probably restart the computer to see what that would do, even tho the end of the flash utility didn't suggest to. It went back to having 4 region resets and was already at region 1, so I deleted that part of the question in the post. Guess you saw it before I could take it down.
Just to add, I tried a Maxell disc and it burned ok. Both the Fuji and Maxell are 16X media but 12X is the max the burner will do using Nero. Strange. -
Without info from you there is no solution.Originally Posted by Trailryder
Pioneer DVR-112D connects but won't burn
By JessW in forum DVD & Blu-ray WritersReplies: 19Last Post: 1st Jul 2008, 00:41 -
Pioneer 112D - Dissapears from Devices when reading a disc at 50%
By faramith in forum DVD & Blu-ray WritersReplies: 4Last Post: 6th Nov 2007, 13:46 -
Pioneer 112 or 112D?
By blacktooth in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Aug 2007, 18:09 -
Pioneer dvd-rw dvr-112D Driver Update
By scustalow in forum DVD RippingReplies: 1Last Post: 27th Jul 2007, 14:16 -
Pioneer 112D problems
By Xande in forum DVD & Blu-ray WritersReplies: 1Last Post: 28th May 2007, 22:13
