Hi,
I have bunch of MPEG files (recorded with camera). I want to make them as a DVD with some 'titles' between each file, which displays description of the file which going to be played next..
How to convert 20 mpeg files into single DVD? How to add titles (not sub titles).
Is there any free software available? fast and reliable?
Assuming these are DVD compliant, then GUIforDVDAuthor is a reliable free authoring tool. If you want simple titles then you can use menu screens that auto-activate after a time period and chain things together - e.g.
Main Menu -> Title Screen menu 1 -> Clip 1 -> Title Screen Menu 2 -> Clip 2 and so on.
It's not elegant, but it works and it saves you having to create and encode video titles.
If you do want clips then I would use gimp to create still iamges of your text, then load them with Avisynth into HCEnc to encode, then drop them in between the clips when authoring with GUIForDVDAuthor.
There is no free solution that I know of that will do this quickly for you - it is going to take some effort on your part.Read my blog here.
Extract Video files from DVD
By thumpy in forum Video ConversionReplies: 3Last Post: 20th Apr 2010, 23:37 -
Data files into a Video DVD
By galactica in forum MacReplies: 13Last Post: 19th Jun 2009, 08:16 -
how to add non-video files to a video dvd
By spiritgumm in forum Authoring (DVD)Replies: 3Last Post: 18th Apr 2008, 21:17 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 08:52 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 03:24
