I am new to video editing and have a simple question. If I want to record a sporting event in HD with my hdvr and HDTV. Can I later use the ADVC110 to transfer the program to my computer. (macbook pro)
Is that possible, how much quality loss would I be looking at? I am still not sure what all the differences are between the 110 and a minidv camcorder. I am looking to buy one or the other real soon.
Any information would be great. Thanks
A mini-DV camcorder is a camera.
The ADVC110 is an analogue-to-DV conversion device.
Some DV cameras will do the same job as an ADVC110 by allowing analogue input and DV pass-through, but most do not.
Using either method (assume the camera supports analogue-to-DV will work, however if this is a regular thing then the ADVC110 is certainly more convenient.
Quality will be reduced to around SD level.Read my blog here.
Thanks for the reply.
Is there a way to keep it close to HD level? What about just hooking a firewire cable to the hdvr to my computer? Would that be better? -
What HDVR do you have? If it has a IEEE-1394 output that works for HD you may not need the ADVC. The ADVC-110 takes SD analog composite or S-Video in and outputs DV format over IEEE-1394. DV format is 720x480 or about DVD quality.Originally Posted by john22
The IEEE-1394 from normal cable DVR boxes may be HD MPeg2_TS depending on model and local cable company policy. -
Scientific Atlanta Explorer 8300hd, with Comcast.
Ill try it when I get a firewire cable and see what happens. Not a huge deal. My main purpose is going to be using a camcorder or advc110 to transfer home vhs tapes to my computer for editing. -
Extracting the MPeg2 transport stream will require some tech wizardry. See hereOriginally Posted by john22
http://www.macosxhints.com/article.php?story=20040426151111599
In some areas, Comcast only passes local channels.
Otherwise connect S-Video and audio to the ADVC.
Canopus ADVC110 or other converters
By pdx10 in forum Capturing and VCRReplies: 3Last Post: 13th May 2009, 14:35 -
Anybody Need a Canopus ADVC110 to Capture With?
By Endzone in forum Capturing and VCRReplies: 2Last Post: 8th Jan 2009, 17:09 -
ADVC110 to Studio 10 Capture
By jimlong in forum Capturing and VCRReplies: 3Last Post: 16th Aug 2008, 09:41 -
New ADVC110 does not show up as available capture device
By tonyp2 in forum Capturing and VCRReplies: 16Last Post: 12th Jun 2008, 22:01 -
Viewing TV using Canopus ADVC110
By cblmdm in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2007, 22:22
