Hello,
I own a Panasonic DMR-HS2 and every time I put a disc in it, be it blank or a factory DVD release, I get a U11 message. When I try to record on a blank disc the machine tells me the disc is not blank and incompatible. Does anyone know what is wrong and is there anything I can do to fix this?
Thanks,
Sam
Sounds like the disc sensor is dirty or faulty. You could try blowing out the unit with canned air, especially around the drive tray and laser. You could also try unplugging the unit for 30 minutes or longer to see if it will reset.
Otherwise, it's time for the repair shop if it is under warranty or replaced if not.Google is your Friend
Panasonic DMR-HS2 power on failure
By rmhartman in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Feb 2012, 15:19 -
Panasonic DMR HS2 (Setup Mode?)
By philo in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jun 2009, 13:14 -
Panasonic DMR-HS2 - shuts down when I try to record
By donmeyer2 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Sep 2008, 23:35 -
Problem with Panasonic DMR-HS2
By rmhartman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Feb 2008, 16:07 -
Help ! - I can't get my Panasonic DMR-HS2 to open - crazy machine......
By agent31 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 13th Sep 2007, 03:12
