hi, how do i join 2 avi movies into 1 big movie and what settings would i need to set in Virtualdub Mod?
Results 1 to 26 of 26
I got a message saying can not append segment. The sizes are different (608 x 352 vs 688 x 400)Originally Posted by AlanHK
That's right, you can't. One will have to be reencoded to the same resolution as the other if you really must join them. And other parameters will have to be the same as well (codec, for example, and audio type and bitrate), or they won't join. Maybe if you'd explain why you think you have to join them, a workaround can be suggested.
How can we work around it? The reason why so when it comes to the final part i would have one big movie to work with.Originally Posted by manono
If you are going to leave them as 1 big movie that is one thing, if you are going to convert to something else, MPG for example, use an encoder that will take both files as is and encode them as 1 file.
Example TDA 3 will encode from avi to DVD and let you add more than one file. Or TMPGEnc Xpress will take files and encode them. Output is selectable for all to 1 file or each file encode to separate files.
IOWs a little more detail on what is the final part. -
I am confused. All i wanted is to join AVI's together.Originally Posted by TBoneit
You have to re-encode one file so it matches the other. Then join together.
He's a liar and a murderer, and I say that with all due respect. -
steveryan, The sizes i gave above, Is it possible to re-encode each part and set them both at 720 x 480 that means i would change the sizes?Originally Posted by steveryan
Yes, you could re-size/re-encode both parts to 720x480 and then join together. Is it worth it? I'd say no, you'll be losing quality on both parts.
What would be the best way? Encode them at the same size they were downloaded? Which one should i encode at 608 x 352 or 688 x 400? I thought 720 x 480 is the good quality?Originally Posted by steveryan
Sorry, my brain isn't working
720x480 wouldn't suit as it would be the wrong aspect ratio. Your two files are very close to having the same aspect ratio so re-encode either of the files to the same resolution as the other one.
How do i tell if my movie is NTSC or PAL and low resloution or not?Originally Posted by steveryan
When you said "The reason why so when it comes to the final part i would have one big movie to work with."
That implied you were then going to do something else to them beyond watching them.
If you're just going to watch them? Then leave them alone and don't join them. Anything you do will reduce quality. -
It doesn't say anything in the feilds/s boxOriginally Posted by steveryan
Frames, not fields.
Frames isn't telling me NTSC or PAL all it says is 23.976Originally Posted by steveryan
Ok what are all the numbers for NTSC film and what are the numbers for PAL film?Originally Posted by TBoneit
Half-way down on the right-hand side are two boxes that indicate "NTSC" and "PAL". Underneath the "Fields/s" box.Originally Posted by php111
Have a look at "What is DVD" on the left <<<<<<<<<<<<<<Originally Posted by php111
The "Technical Info for DVD-Video" section.
Jim -
1. I do not see at all that my movie is in NTSC or PAL. Yes i see the two buttons but it doesn't tell me what my movie is in. 2. I don't see that section.Originally Posted by Jim44
Huh. I can't recall ever not seeing an "NTSC" or "PAL" indication, but I guess it would be possible.Originally Posted by php111
https://www.videohelp.com/dvd2. I don't see that section.
About half-way down the page.
Jim -
I'm a man who is very patient, but I have to say this - read some guides. What your're asking is so basic, why should I do the legwork for you?
Apologies if you're offended but the question you have asked has been asked 100's of times.He's a liar and a murderer, and I say that with all due respect.
Question about Joining movies.
By eliqush in forum Video ConversionReplies: 4Last Post: 21st Jun 2009, 13:40 -
Joining Image and Two Separate QuickTime Movies
By lindylex in forum EditingReplies: 2Last Post: 13th Mar 2008, 12:30 -
joining up .mpg movies
By natty in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2008, 06:14 -
joining avi's
By php111 in forum EditingReplies: 15Last Post: 5th Aug 2007, 10:05 -
joining avi movies
By natty in forum Newbie / General discussionsReplies: 4Last Post: 5th Aug 2007, 04:46
