What basic equipments required to set up a VOIP connection ?
People who I probably am more like.
Well a fast internet connection will work wonders.
When you sign up for Voip service, they will give you an ATA unit which will rin between your modem and your phone.
Thats really about it.
LG -
LG is correct...
Also depends on what you're wanting to do with it. At home I'm now using VOIP with nothing more than the ATA and highspeed. For work, I've set up a full phone system built around Trixbox and using IP phones.
Interesting enough, you can do the latter for next to nothing (cost) as all the software is free...
Family is moving at the end of this month to a new home - I'm probably going to set up a phone system in the house. Use ATA for lines 1 and 2 (most homes are wired for two lines) and IP in a small home office. Nice is that you end up with an in-house intercom system, multiple incoming and outgoing lines and all for about $10 per month.
Edit: I would recommend NOT using VOIP if you don't have a cell phone. VOIP will go down when you have any problem with any of power / internet / provider... -
Originally Posted by SquirrelDip
That is one HUGE thing to remember. Most people dont really think about it either. No power = no computer/internet = no voip phone.
So as Squirrel said, even have a prepaid phone if you dont want the monthly cost. But have something for emergencies. -
Buy a UPS if you want emergency power.
A UPS helps and I would recommend having one (I do) but it's only one part of the long list of things that can bring down your VOIP. IMO, a cell phone is still a necessity if you want VOIP.
Also, and this goes for any phone, you should always have at least one non-cordless / non-powered phone on hand...
Convert from MKV to TS file with subtitle and these requirement
By kucku in forum Video ConversionReplies: 1Last Post: 15th Jun 2011, 21:25 -
H.264 MOV Requirement
By NautTboy in forum Software PlayingReplies: 3Last Post: 14th May 2010, 18:55 -
Newbie ?: SDHC requirement and HD recording
By carlsjunior99 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 30th Mar 2010, 15:45 -
Review rating minimum vote requirement
By Supreme2k in forum FeedbackReplies: 6Last Post: 2nd Sep 2009, 18:50 -
system requirement for x264
By Shaorin in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2007, 01:18
