Hey guys/gals,
Wasn't sure where to ask this one, i have quite a few SVCDs and would like to burn them to DVD to take advantage of the larger capacity (3-4 movies per DVD). I don't want to reconvert them, just burn them as is. Can this be done? (I'm currently using Nero). If it is doable do i burn these as SVCD or would i burn these as Data? Any help or suggestions much appreciated!
Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Get:
SVCD2DVDMPG
The freeware version will demux the video (which doesn't need to be changed) and convert the audio to DVD standard.
Then you can author a normal DVD using the resulting video and audio files.
I don't know if Nero will accept these though, it tends to reconvert everything you give it.
I use GuiforDVDauthor, freeware, simple to use for this kind of project.
You can use Nero for the final burn of the VIDEO_TS folder, (or ImgBurn preferably). -
you can patch the headers, some players will take it, some wont. SVCD is 480x480, and as such isnt DVD spec. For best results you might have to change to a compliant frame size.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Originally Posted by Forum Troll
Try the SVCD2DVD v2.5 demo - if memory serves - as long as you are not converting PAL to NTSC then there is no watermark etc and should take a matter of minutes.
I Need help simply converting files and burning to DVD. anyone available 1
By Majikwiz in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2011, 19:15 -
Burning DVD's after converting to .vob files
By Joyful Noise in forum Newbie / General discussionsReplies: 1Last Post: 7th Mar 2010, 00:37 -
Stuttering video when converting/burning to DVD
By hans030390 in forum Video ConversionReplies: 9Last Post: 26th Feb 2010, 03:20 -
Trouble converting MKV to DVD and burning....
By DVDNewb in forum Newbie / General discussionsReplies: 4Last Post: 11th Dec 2007, 00:14 -
.Rmvb Converting/ Burning DVD problems.
By evan11567 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2007, 01:35
