I was wondering, in Ulead dvd moviefactory 5 you can choose between several menu's.
Every menu has a different mouse-pointer like a feather or a cirkel.
I know I can't edit the menu because it's and UFO file, for example by replacing
the mouse-pointer .jpeg by a square.
But is there any way I can change that mouse-pointer in the program itself?
Of maybe create a whole new template?
Kate: What's the big thing that happens every Monday at one o'clock?
Tom: The dog outside the pub scratches itself...?
Kate: The plane from Broken Hill arrives! -
You can edit UFO files with Photoimpact which is Uleads program, if you search around you might be able to find an older version pretty cheap. Look for at least version 7 or 8 .
I haven't messed with it much but you can only edit so much in templates. Another tip is you can can add templates from other programs. For example you can download the trial versions and any templates available in that program you don't have you can add to your template folder and they'll show up in the selections.
The button you are referring too can most likely be changed to anything, post the file and I'll edit it and you can see if it works.
Can't help you with switching it within the program because I don't have it. -
I've purchased Photoimpact 12,
but I can't really find how I
can change the mouse-pointer.Kate: What's the big thing that happens every Monday at one o'clock?
Adding 'copyright' info to video clip in Ulead DVD Moviefactory 6
By colinb1 in forum EditingReplies: 3Last Post: 19th Apr 2011, 08:13 -
Ulead DVD MovieFactory 6 Plus Menu Option Question
By SCDVD in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 14:42 -
Ulead DVD Moviefactory 6 Plus (trying to get to grips after UDVDWorkshop2)
By dvdfever in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2009, 21:01 -
Joining in Ulead DVD MovieFactory - does it lead to worse quality?
By rosbif08 in forum EditingReplies: 2Last Post: 6th Aug 2008, 22:32 -
Questions about Ulead DVD MovieFactory 6
By cheeseandcrackers in forum Authoring (DVD)Replies: 5Last Post: 18th Jun 2007, 11:46
