  1. VCDHELP.COM SAYS
    You can fit 740 MB on a 74 min CD and 800 MB on a 80 min CD on a VCD!
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    SO WHEN I TRY TO BURN A 788MB MOVIE ONTO A 80 MIN CD-R, NERO COMPLAINS THAT THE CD DOESN'T HAVE ENOUGH ROOM TO BURN ONTO..WHAT DO I DO OR WHAT DID I DO WRONG?
    ALSO WHAT BRAND OF 80 MIN CD'S DO YOU GUYS USE THAT WORKS VERY GOOD? IT MIGHT BE MY CD-R..JUST WONDERING..PLEASE HELP. THANKS
    _________________
    JuPiTeR172
    vcd_man40@hotmail.com
    <font size=-1>[ This Message was edited by: jupiter172 on 2001-07-21 11:01:46 ]</font>
    <font size=-1>[ This Message was edited by: jupiter172 on 2001-07-21 11:51:24 ]</font>
    <font size=-1>[ This Message was edited by: jupiter172 on 2001-07-21 18:10:23 ]</font>
  2. You are burning it as a VCD rather than a CD-ROM aren't you?
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. YES I AM TRYING TO MAKE A VCD..IT SAYS I NEED TO PUT IN A BIGGER CD..DOES IT MATTER ON WHAT CD-R I USE(COMPANY WISE)? I AM USING A 80MIN GIGASTORAGE CD-R AND USING NERO TO BURN.
  4. are you choosing vcd in the right hand side of nero? Nero measures the size of a vcd by the minutes rather then the mb's. so if your movie shows up as 81 minutes it will say that. make sure you follow the direction on how to set up bero to make a vcd. there are guides on this site that will show you exactly how to do it.
  5. oops, i meant the left hand side of nero.
  6. I FOLLOWED THE GUIDES EXACTLY...NOT SURE WHAT I DID WRONG.
