when i compile with DVD lab pro i get a receive virtual memory error and DVD lab aborts the project. how do i retrceive virtual memory?
Virtual Memory usually refers to space the program is using on the hard drive when it runs out of system RAM. That would be normal when your file size is larger than your RAM size.
Do you have sufficient space on your hard drive? -
Virtual Memory exists as a temp file on the hard disk. When Windows runs out of physical memory, it pages the excess to temp files.
http://www.kiva.org/about -
Originally Posted by guns1inger
i dont know where the to find the info but i do know its
(if u can tell me where to find the info, i will post more :])
2001
35 gig
dell
i got 15 free gigs
is that in DVD Lab PRO?Originally Posted by guns1inger
Originally Posted by edDV
im compiling a 6 gig project and it didnt work, then i cut it to 1 gig to see if that was the problem and it didnt work, so im clueless lol :[ could it be unknown programs running?if so where do i turned them off? -
Mega projects are a DLP2 feature. You should set your project to be a Mega Project at the outset, but I also thought you could set it afterwards. Let me look into that.
In the meantime, under the Project menus is a Free Memory option that might help you compile.
How much ram do you have in your system ? Hint : Right-click on My Computer and select Properties. The answer is on the first tab.
Edit : Looking at the wrong version of DLP (I still have DLP 1.53 on my machine, as well as DLP2.x). Under the Project menu is Mega Projects, and within this, Set to Mega Project. This is generally used if you have a lot of menus, and uses a disc cache instead of RAM.
The other option that seems to help in some large projects is to do your editing, save the project, then exit DLP. Start it up again, load the project and compile immediately.Read my blog here.
In DVDLab Pro there is option that you can free up memory. try that option
it may be help you to solve the problem
virtual memory too low?
By deadman1972 in forum Newbie / General discussionsReplies: 3Last Post: 14th Apr 2009, 09:22 -
how to receive encryted channels HELP HELP PLS
By Solona in forum Capturing and VCRReplies: 3Last Post: 3rd Feb 2009, 22:42 -
VLC Media Player hangs and starts hogging lots of Virtual Memory
By shiningwizard in forum Software PlayingReplies: 2Last Post: 27th Aug 2008, 08:17 -
Only receive Black & white Picture on TV
By cincsoc442 in forum Video ConversionReplies: 9Last Post: 6th Aug 2008, 09:05 -
Xvid4PSP making Windows give Virtual Memory low message
By godfist314 in forum Video ConversionReplies: 5Last Post: 22nd Jul 2008, 14:09
