Just that quick question is all... I have been reading documents on AviSynth, and I can't seem to find a mention of selecting part of a file (if it is possible). I just want to apply the tweak filter to only a section of the file. Is there an argument I can put in the code anywhere to do this, just like starting frame and ending frame?
Use the Trim function to break the video into sections. Then apply the filter to the section you want, then reassemble.
Buy My Books -
ApplyRange is a special case of Animate where start_args = end_args, and present in v2.51. It can be used when you want to apply a certain filter on certain range of frames of a clip. Another difference with Animate is that args can't contain a clip. Starting from v2.53 it supports audio, and start_frame can be equal to end_frame (such that only one frame is processed).
http://avisynth.org.ru/docs/english/corefilters/animate.htm -
Blast...I need to be more detailed when I read... Thanks very much.
A=Trim(0, 1000)
B=Trim(1001,2000).Tweak(....)
C=Trim(2001,10000)#10000 here is the last frame
A++B++C
or
ApplyRange(0,1000,"Tweak",hue=-30,sat=1.2,bright=20,cont=0.9)
#0,1000 are start/end frames -
I think this is neater.
Trim(0, 1000) ++\
Trim(1001,2000).Tweak(....) ++\
Trim(2001,0) #0 = last frame when at end of range
I do this a lot when filtering logos which fade in and out through a show. -
Thanks for the tip, Alan (always had to search for the last frame number).
AviSynth and Filter Order
By sambat in forum EditingReplies: 3Last Post: 11th Jan 2012, 11:04 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 09:36 -
Need Avisynth filter
By fubuki81 in forum RestorationReplies: 5Last Post: 30th Sep 2008, 14:04 -
How to apply a filter to just a part of the movie with VirtualDub
By Drakul in forum EditingReplies: 5Last Post: 19th Sep 2008, 18:08 -
Logoaway filter for AviSynth?
By DRP in forum Video ConversionReplies: 2Last Post: 8th Aug 2008, 05:30
