any of my movies i got that use quicktime, last about a half a second then goes green , with stuttery sound and sometimes mouse lock out, ive got adobe after effects training dvds which i cant view as that uses quicktime, any one know of a fix?
i downloaded quicktime from the main site, i have used quicktime alternative , i uninstalled both and tried reinstalling again same thing, i have noticed that if i run "with win 95 compatibility" it works but very grainy
I used to have green problems once with video. I believe it was a directx issue. Do you have updated directx drivers for your video card?
Also try vlc or mediaplayerclassic - they have built in codecs and may or may not support quicktime.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Alternate Method for Creating Poster Frames for Quicktime Movies???
By m021478 in forum MacReplies: 2Last Post: 11th Dec 2011, 17:06 -
Problems importing Quicktime movies into Sony Vegas
By matthewjohn23 in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2011, 21:31 -
MKV File: QuickTime (With Perian) - Green Screen; VLC - No Problem
By Valentin in forum Software PlayingReplies: 2Last Post: 4th Aug 2010, 17:24 -
Error 2048 Quicktime Problem (Home Movies)
By cliffm10 in forum Software PlayingReplies: 0Last Post: 19th Apr 2010, 12:06 -
Joining Image and Two Separate QuickTime Movies
By lindylex in forum EditingReplies: 2Last Post: 13th Mar 2008, 13:30
