Hello,
I've just installed Adobe Premiere 6.0 Tryout to do some editing (Premiere Pro 2 not working). The problem is that the source files are in different audio video formats & for example I can play them normally in Media Player, but in the editing software there is only sound without video (although on the miniature there is video visible and you can even play it). Is there some kind of pack that I can install to have everything that I need? Now I have ffdshow and xvid and I can play everything I need but it is not visible in the editing software. I'm using Windows Vista.
Funny/interesting thing is that something may work in Virtual Dub and not work in Adobe Premiere. Example:
Video A | In Virtual Dub: sound OK, video OK | In Adobe Premiere: no sound, video OK
Total duration is 0:07:46:01
Size is 185,29MB bytes (average frame = 16,91KB bytes)
There are 91 keyframes, 11560 delta frames.
Frame rate is 25,00 fps
Frame size is 720 x 576
Depth is 24 bits.
Compressor: 'XVID', XviD MPEG-4 Codec
Audio track 1:
Size is 7,11MB bytes
Rate is 48000 samples/sec, stereo
Sample size is 16 bits
Compatible compressor: MPEG Layer-3 Codec
Compression ratio is 0,22:1
Video B | In Virtual Dub: sound OK, video OK | In Adobe Premiere: sound OK, NO video
Total duration is 0:10:19:13
Size is 2,04GB bytes (average frame = 145,74KB bytes)
This movie appears to have DROPPED FRAMES
There are 15226 keyframes.
There are 262 empty frames.
Depth is 24 bits.
Compressor: 'dvsd'
Audio track 1:
Size is 113,43MB bytes
Older versions of Premiere don't like mpeg-4 (Xvid/Divx) all that much. It is a poor choice for footage that needs to be edited, so most editors don't work well with it. The simplest solution would be to load it into virtualdub and save it as DV avi, then edit it.
Read my blog here.
Subs visible in MPC but not in tv?
By stargazer500 in forum SubtitleReplies: 4Last Post: 18th Nov 2011, 15:43 -
Video not visible
By bluechip0032 in forum Software PlayingReplies: 2Last Post: 15th Aug 2010, 22:43 -
DVDlab Pro: Text set as visible isn´t visible in the result
By Alex89 in forum Authoring (DVD)Replies: 14Last Post: 12th Aug 2010, 07:09 -
How can I make a second session visible?
By KneeRow in forum Authoring (DVD)Replies: 1Last Post: 27th Dec 2009, 17:15 -
black video edit to visible video if possible
By andy in forum EditingReplies: 7Last Post: 5th May 2007, 08:04
