I have CATV with a DVR. No HDTV. Here is the ideal setup I would like to have:
Download movies from the DVR to a DVD recorder. Hard drive greater than 250MB. Burning to DVD's would be very minimal. Abiliy to upload music mp3's to the DVR. Ability to preview all movie and music titles via menus. Download DVD recorder to an external hard drive.
Transport the external hard drive over a thousand miles and upload music and movies to a second DVD recorder (or some sort of hardware) that would allow the music and/or movies (no HDTV) to be played on a surround sound system (selection of titles via menus).
Total budget for new hardware $600 to $800. I would like to stay away from using my laptop computer if possible, but not a problem if nesessary.
Is this possible? If so, any recommended systems?
Thanks in advance.
depending on your preferences, you can get it for easily under $600 (or in 6-8 hundred range).
cpu+mb: $200 (or under)
case+ps: under $100
2G memory: $80
internal+external drives (300G ea): $100-120
keyboard, mouse, dvdr, surround-card:under $100
video card (basic, w/ tv-out): ~$100 (maybe even use built-in on MB)
the problem is the portability. If you're talking about having two complete systems, then that increases your costs.
If you can use your laptop for the portability, you'd be set (most laptops have tv-out). The only other thing you'd need is a 1/8 stereo to RCA plug adapter. You'd only get stereo though. Surround for your laptop would be another $100 (approx.)
Looking for ideal converter
By xtof in forum Video ConversionReplies: 11Last Post: 4th Oct 2011, 17:34 -
Ideal Blu-ray Copy
By Quincyboy in forum Blu-ray RippingReplies: 3Last Post: 28th Apr 2011, 10:23 -
Ideal format to convert to
By The Monarch in forum Blu-ray RippingReplies: 2Last Post: 23rd Jan 2011, 20:35 -
Ideal audio software tools ?
By tecbox in forum AudioReplies: 3Last Post: 22nd Feb 2009, 16:57 -
Ideal DVD Recorder for this job...
By retroborg in forum DVD & Blu-ray WritersReplies: 9Last Post: 17th Sep 2007, 15:29
